Installing PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Upper Case
  1. Installing PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Upper Case, Battery: step 1, image 1 of 2 Installing PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Upper Case, Battery: step 1, image 2 of 2
    • Use your thumbs to push the two battery retaining tabs away from the battery.
    • The battery should pop up enough to rotate it toward yourself and lift it out of the lower case.
  2. Installing PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Upper Case, Memory Door: step 2, image 1 of 1
    • Remove the three 2.3 mm Phillips screws securing the memory cover to the lower case.
  3. Installing PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Upper Case: step 3, image 1 of 2 Installing PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Upper Case: step 3, image 2 of 2
    • Lift the memory cover slightly and pull it toward yourself to remove it from the lower case.
  4. Installing PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Upper Case, Upper Case: step 4, image 1 of 1
    • Remove the following ten screws:
    • Two 14.7 mm shouldered Phillips.
    • Three 12.3 mm Phillips.
    • One 3.8 mm T8 Torx.
    • One 6.8 mm T8 Torx.
    • Three 1.3 mm Phillips.
  5. Installing PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Upper Case: step 5, image 1 of 2 Installing PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Upper Case: step 5, image 2 of 2
    • The ZIF cable is located underneath the bottom RAM slot. If your PowerBook has both RAM slots occupied, make sure to remove the RAM chip.
    • Use your fingernails to separate the ZIF cable lock away from its socket.
    • The ZIF cable lock will move about a millimeter away from the socket before it stops (see picture 2). Do not try to remove the ZIF cable lock.
  6. Installing PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Upper Case: step 6, image 1 of 1
    • Use the tip of a spudger to slide the trackpad ribbon cable out of its socket.
  7. Installing PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Upper Case: step 7, image 1 of 1
    • Remove the four 3.4 mm Phillips screws from the PC card side of the PowerBook.
    • When replacing these screws, you must reinstall each screw in the correct order. Begin by installing the screw closest to the display hinge, and go out from there.
  8. Installing PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Upper Case: step 8, image 1 of 1
    • Remove the four 3.4 mm Phillips screws from the DVI connector side of the PowerBook.
    • During reassembly, make sure to reinstall the two screws on the right into their appropriate locations, and not the DVI port anchor holes.
  9. Installing PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Upper Case: step 9, image 1 of 2 Installing PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Upper Case: step 9, image 2 of 2
    • Depress the display latch release button and open your display.
  10. Installing PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Upper Case: step 10, image 1 of 2 Installing PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Upper Case: step 10, image 2 of 2
    • Starting near the display, lift the upper case straight up off the lower case, minding any cables that may get caught.
Attached Documents
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 12
All Time: 4,202
