PowerBook 180 Modem Replacement
  1. PowerBook 180 Modem Replacement, Modem: step 1, image 1 of 2 PowerBook 180 Modem Replacement, Modem: step 1, image 2 of 2
    • Remove the Ni-Cad battery from the PowerBook 180.
    • Slide the arrows toward the front of the computer until the battery can slide out.
  2. PowerBook 180 Modem Replacement: step 2, image 1 of 2 PowerBook 180 Modem Replacement: step 2, image 2 of 2
    • Removing the screws securing the bottom plate from the PowerBook 180.
    • There are 5 Torx T8 screws, 4 of which are located on the bottom and 1 on the back above the modem port.
  3. PowerBook 180 Modem Replacement: step 3, image 1 of 2 PowerBook 180 Modem Replacement: step 3, image 2 of 2
    • Your computer should look like the two pictures after the bottom plate is removed.
  4. PowerBook 180 Modem Replacement: step 4, image 1 of 2 PowerBook 180 Modem Replacement: step 4, image 2 of 2
    • Locate the modem board, which is next to the DC-in port.
    • There are two Torx T8 screws marked in red in the pictures. Remove these screws and pull up on the modem board to remove.
    • To reassemble your PowerBook, follow these instructions in reverse.
Jack Byrnes
1,244 Reputation
2 Guides authored
Master Techs Member of Master Techs
Community
321 Members
1,508 Guides authored
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 12
All Time: 1,643
