PowerBeats2 Wireless Headphones by Dr. Dre Battery Replacement
  1. PowerBeats2 Wireless Headphones by Dr. Dre Battery Replacement, Locate Battery.: step 1, image 1 of 1
    • The battery is located inside the right side ear piece.
  2. PowerBeats2 Wireless Headphones by Dr. Dre Battery Replacement, Heat Right Side.: step 2, image 1 of 1
    • Heat the right side gently at 140 F for about 3 minutes.
    • Do not over heat or it will melt the housing.
  3. PowerBeats2 Wireless Headphones by Dr. Dre Battery Replacement, Remove Battery Cover/Casing: step 3, image 1 of 2 PowerBeats2 Wireless Headphones by Dr. Dre Battery Replacement, Remove Battery Cover/Casing: step 3, image 2 of 2
    • After heating, gently remove the cover/casing as shown in the picture.
    • Take your time and re-heat if cover/casing does not remove smoothly.
  4. PowerBeats2 Wireless Headphones by Dr. Dre Battery Replacement, Desolder & Replace Battery: step 4, image 1 of 1
    • Desolder battery using soldering iron and replace with replacement battery.
  5. PowerBeats2 Wireless Headphones by Dr. Dre Battery Replacement, Reattach Battery Cover/Casing: step 5, image 1 of 2 PowerBeats2 Wireless Headphones by Dr. Dre Battery Replacement, Reattach Battery Cover/Casing: step 5, image 2 of 2
    • After battery is replaced, apply super glue to the border of the inside of the battery cover/casing and put it back in place.
    • Use small clamps/binder clip to hold the housing in place while the super glue dries up.
Faizan Naveed
3,294 Reputation
8 Guides authored
Mobile Device Repair Factory Member of Mobile Device Repair Factory
Business
1 Member
16 Guides authored
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 68
All Time: 26,900
