Power Mac G4 MDD Hard Drives Replacement
  1. Power Mac G4 MDD Hard Drives Replacement, Case: step 1, image 1 of 2 Power Mac G4 MDD Hard Drives Replacement, Case: step 1, image 2 of 2
    • The Power Mac G4 MDD: the last, and the fastest G4-based Mac. This computer boasted up to a Dual 1.42GHz PowerPC G4 CPU (though I have a single 1.25GHz).
    • Two USB 1.1 Ports
    • Assorted Audio
    • Video (ADC & DVI)
    • Networking (RJ-45 Ethernet/56k Modem)
    • Some later model MDD's (such as the dual 1.42GHz) Have a FireWire 800 Port Here:
  2. Power Mac G4 MDD Hard Drives Replacement: step 2, image 1 of 3 Power Mac G4 MDD Hard Drives Replacement: step 2, image 2 of 3 Power Mac G4 MDD Hard Drives Replacement: step 2, image 3 of 3
    • Unplug the computer.
    • Unplug the power supply and all external connections from the computer.
    • Pull on the side lever and lower the side of the case.
  3. Power Mac G4 MDD Hard Drives Replacement, Hard Drives: step 3, image 1 of 1
    • The hard drive cages are located here.
  4. Power Mac G4 MDD Hard Drives Replacement: step 4, image 1 of 3 Power Mac G4 MDD Hard Drives Replacement: step 4, image 2 of 3 Power Mac G4 MDD Hard Drives Replacement: step 4, image 3 of 3
    • Cage 1
    • Start by removing this screw.
    • Remove the IDE ribbon cable from the motherboard.
  5. Power Mac G4 MDD Hard Drives Replacement: step 5, image 1 of 2 Power Mac G4 MDD Hard Drives Replacement: step 5, image 2 of 2
    • Now, remove the power connecton from the drives.
  6. Power Mac G4 MDD Hard Drives Replacement: step 6, image 1 of 3 Power Mac G4 MDD Hard Drives Replacement: step 6, image 2 of 3 Power Mac G4 MDD Hard Drives Replacement: step 6, image 3 of 3
    • Now, push this tab down, and pull the cage towared you.
    • Now, you can set cage 1 aside.
  7. Power Mac G4 MDD Hard Drives Replacement: step 7, image 1 of 2 Power Mac G4 MDD Hard Drives Replacement: step 7, image 2 of 2
    • Cage 2:
    • Remove this Phillips screw:
    • Disconnect this IDE ribbon cable from the logic board.
  8. Power Mac G4 MDD Hard Drives Replacement: step 8, image 1 of 2 Power Mac G4 MDD Hard Drives Replacement: step 8, image 2 of 2
    • It's likely that there is a cable clip holding the ribbon cable to the case.
    • To remove it, push the end, and it should pop up.
  9. Power Mac G4 MDD Hard Drives Replacement: step 9, image 1 of 3 Power Mac G4 MDD Hard Drives Replacement: step 9, image 2 of 3 Power Mac G4 MDD Hard Drives Replacement: step 9, image 3 of 3
    • With the clip free, pull on this tab, lift the cage up, until it clicks, and pull it away.
    • Now, set the cage on top of the CPU, and remove the power connectors.
  10. Power Mac G4 MDD Hard Drives Replacement: step 10, image 1 of 2 Power Mac G4 MDD Hard Drives Replacement: step 10, image 2 of 2
    • Once the cables are free, set the drive cage aside.
    • To remove the hard drives from the cages, remove the four screws on the sides of the cage that are connected to the drives, than slide the drives out.
    • The two cages are cross compatible and can be put in either rack.
    • The MDD does not have a 128GB drive limit like older macs, My MDD has 3 Drives (A 400GB Hitatchi Deskstar, 40GB Seagate Baracuda 7200.7, and a 30GB Quantum Fireball LCT).
    • Note the ID jumpers on the two drive set. One is set to Master, the other to slave. A single drive can be set to Cable Select.
Chris Green
37,065 Reputation
49 Guides authored
Master Techs Member of Master Techs
Community
321 Members
1,482 Guides authored
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 110
All Time: 47,124
