HP EliteBook 840 Aero G8 Power Connector Cable Disconnection
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
  1. HP EliteBook 840 Aero G8 Power Connector Cable Disconnection, Before you begin: step 1, image 1 of 2 HP EliteBook 840 Aero G8 Power Connector Cable Disconnection, Before you begin: step 1, image 2 of 2
    • Before starting your repair, allow your laptop's battery to drain below 25%—a charged lithium-ion battery is a potential safety hazard if accidentally damaged.
    • Save your work, fully shut down your laptop, and unplug all cables.
  2. HP EliteBook 840 Aero G8 Power Connector Cable Disconnection, Unfasten the bottom cover: step 2, image 1 of 2 HP EliteBook 840 Aero G8 Power Connector Cable Disconnection, Unfasten the bottom cover: step 2, image 2 of 2
    • Despite the standards, Phillips screwdrivers can vary in size and shape—two drivers labeled as the same size may fit differently in the same screw. Use the size that fits the most snug into the screw head to avoid stripping it.
    • Use a Phillips screwdriver to fully loosen (but not remove) the five captive screws securing the bottom cover.
  3. HP EliteBook 840 Aero G8 Power Connector Cable Disconnection, Release the bottom cover clips: step 3, image 1 of 3 HP EliteBook 840 Aero G8 Power Connector Cable Disconnection, Release the bottom cover clips: step 3, image 2 of 3 HP EliteBook 840 Aero G8 Power Connector Cable Disconnection, Release the bottom cover clips: step 3, image 3 of 3
    • Position your laptop so the rear edge (with the screen hinge) is closest to you.
    • Insert the flat end of a spudger between the rear edge of the bottom cover and the frame, near the middle screw and ELITEBOOK text.
    • If you're having trouble inserting your spudger, make sure the screw is fully loosened. If necessary, use your fingers to gently pull the screw up.
    • Use your spudger to pry up the cover to release the clip securing it.
    • Leave the spudger inserted under the bottom cover for the next step.
  4. HP EliteBook 840 Aero G8 Power Connector Cable Disconnection: step 4, image 1 of 3 HP EliteBook 840 Aero G8 Power Connector Cable Disconnection: step 4, image 2 of 3 HP EliteBook 840 Aero G8 Power Connector Cable Disconnection: step 4, image 3 of 3
    • Slide your spudger along the rear edge toward one of the corners to release the rear edge clips.
    • Rotate your spudger around the corner and up the edge to release the clips securing the short edge of the cover.
  5. HP EliteBook 840 Aero G8 Power Connector Cable Disconnection: step 5, image 1 of 3 HP EliteBook 840 Aero G8 Power Connector Cable Disconnection: step 5, image 2 of 3 HP EliteBook 840 Aero G8 Power Connector Cable Disconnection: step 5, image 3 of 3
    • Reinsert the flat end of a spudger near the ELITEBOOK text.
    • Repeat the previous step for the other side of the cover to release the remaining clips.
  6. HP EliteBook 840 Aero G8 Power Connector Cable Disconnection, Remove the bottom cover: step 6, image 1 of 3 HP EliteBook 840 Aero G8 Power Connector Cable Disconnection, Remove the bottom cover: step 6, image 2 of 3 HP EliteBook 840 Aero G8 Power Connector Cable Disconnection, Remove the bottom cover: step 6, image 3 of 3
    • Lift and remove the bottom cover.
    • The cover should lift away easily. If you feel resistance, use the flat end of a spudger to release any remaining clips, and check that all screws are fully loosened.
    • During reassembly, slide the clips along the front edge of the cover (opposite the hinge) into their slots on the frame, then lay the cover down. Press firmly around the perimeter to engage all of the clips.
  7. HP EliteBook 840 Aero G8 Power Connector Cable Disconnection, Disconnect the battery: step 7, image 1 of 3 HP EliteBook 840 Aero G8 Power Connector Cable Disconnection, Disconnect the battery: step 7, image 2 of 3 HP EliteBook 840 Aero G8 Power Connector Cable Disconnection, Disconnect the battery: step 7, image 3 of 3
    • Position your laptop so the front edge (opposite the screen hinges) is closest to you.
    • Use the point of a spudger or your fingernail to push on alternating sides of the battery's sliding connector to walk it completely out of its socket.
  8. HP EliteBook 840 Aero G8 Power Connector Cable Disconnection, Disconnect the power connector cable: step 8, image 1 of 3 HP EliteBook 840 Aero G8 Power Connector Cable Disconnection, Disconnect the power connector cable: step 8, image 2 of 3 HP EliteBook 840 Aero G8 Power Connector Cable Disconnection, Disconnect the power connector cable: step 8, image 3 of 3
    • Use the point of a spudger or your fingernail to push on alternating sides of the power connector's sliding connector to walk it completely out of its socket near the left hinge.
    • During reassembly, make sure the side of the connector marked with a black dot is facing up before reconnecting the cable.
  9. HP EliteBook 840 Aero G8 Power Connector Cable Disconnection: step 9, image 1 of 2 HP EliteBook 840 Aero G8 Power Connector Cable Disconnection: step 9, image 2 of 2
    • Use tweezers or your fingers to pull the power connector cable out of its clip.
    • During reassembly, use this photo as a reference to properly route the cable into its clips.
Finish Line
Spencer Day
161,258 Reputation
1,045 Guides authored
iFixit Member of iFixit
Staff
125 Members
24,046 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 62
