Pocophone F1 Battery Disconnect
View statistics:
Past 24 Hours:
Past 7 Days:
6
Past 30 Days:
21
All Time:
298
Comments: 5
5 comments on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 25 minutes
Difficulty: Moderate
Prerequisite Only This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Introduction
Go to step 1 ↓
Prerequisite only! Use this guide to disconnect the battery in your Xiaomi Pocophone F1.
Tools
    1. Pocophone F1 Battery Disconnect, Remove the SIM tray: step 1, image 1 of 3 Pocophone F1 Battery Disconnect, Remove the SIM tray: step 1, image 2 of 3 Pocophone F1 Battery Disconnect, Remove the SIM tray: step 1, image 3 of 3
      • Before you begin, switch off your phone.
      • Insert a SIM eject tool or a paperclip into the small hole on the SIM card tray on the left edge of the phone.
      • Press firmly to eject the tray.
      • Remove the SIM card tray.
      • When reinserting the cards, make sure to properly orient them in the tray.
      Ask FixBot
    1. Pocophone F1 Battery Disconnect, Unfasten the back cover screws: step 2, image 1 of 1
      • Remove the two 2.7 mm-long Torx T3 screws from the bottom edge of your phone.
      Ask FixBot
    2. Pocophone F1 Battery Disconnect, Insert an opening tool: step 3, image 1 of 3 Pocophone F1 Battery Disconnect, Insert an opening tool: step 3, image 2 of 3 Pocophone F1 Battery Disconnect, Insert an opening tool: step 3, image 3 of 3
      • Insert an opening tool between the screen and the back cover at the bottom edge of the screen.
      • Slide the opening tool to the bottom right corner to release the plastic clips holding the back cover in place.
      Ask FixBot
    3. Pocophone F1 Battery Disconnect, Release the clips: step 4, image 1 of 3 Pocophone F1 Battery Disconnect, Release the clips: step 4, image 2 of 3 Pocophone F1 Battery Disconnect, Release the clips: step 4, image 3 of 3
      • Slide the opening tool around the bottom right corner.
      • Slide the opening tool along the right edge of the Pocophone F1 to release the plastic clips.
      Ask FixBot
    4. Pocophone F1 Battery Disconnect: step 5, image 1 of 2 Pocophone F1 Battery Disconnect: step 5, image 2 of 2
      • Slide the opening tool along the top edge of the phone to release the plastic clips holding the back cover in place.
      Ask FixBot
    5. Pocophone F1 Battery Disconnect: step 6, image 1 of 3 Pocophone F1 Battery Disconnect: step 6, image 2 of 3 Pocophone F1 Battery Disconnect: step 6, image 3 of 3
      • Slide the opening tool along the left edge of the phone to release the remaining plastic clips.
      • Try not to remove the back cover all the way yet, the flex cable of the fingerprint sensor is still connected to the motherboard.
      Ask FixBot
    6. Pocophone F1 Battery Disconnect: step 7, image 1 of 3 Pocophone F1 Battery Disconnect: step 7, image 2 of 3 Pocophone F1 Battery Disconnect: step 7, image 3 of 3
      • Carefully fold the phone assembly to the left side of the back cover like you'd open a book page.
      • There are two clips on either side of the rear camera, which may take a little force to release.
      • Avoid tensioning the fingerprint flex cable during this procedure.
      Ask FixBot
    7. Pocophone F1 Battery Disconnect, Unfasten screws: step 8, image 1 of 1
      • Remove the ten 3.2 mm-long Phillips screws.
      Ask FixBot
    8. Pocophone F1 Battery Disconnect: step 9, image 1 of 3 Pocophone F1 Battery Disconnect: step 9, image 2 of 3 Pocophone F1 Battery Disconnect: step 9, image 3 of 3
      • Slide an opening pick under the bottom left corner of the motherboard cover.
      • Slide the opening pick around the corner and along the left edge of the motherboard cover to release the plastic clips holding it in place.
      • Use the opening pick to pry up the motherboard cover.
      Ask FixBot
    9. Pocophone F1 Battery Disconnect, Remove the motherboard cover: step 10, image 1 of 2 Pocophone F1 Battery Disconnect, Remove the motherboard cover: step 10, image 2 of 2
      • Remove the motherboard cover.
      Ask FixBot
    10. Pocophone F1 Battery Disconnect, Remove the back cover: step 11, image 1 of 3 Pocophone F1 Battery Disconnect, Remove the back cover: step 11, image 2 of 3 Pocophone F1 Battery Disconnect, Remove the back cover: step 11, image 3 of 3
      • Use the flat end of a spudger to pry up and disconnect the fingerprint flex connector.
      • Remove the back cover.
      Ask FixBot
    1. Pocophone F1 Battery Disconnect, Remove the protective foil: step 12, image 1 of 3 Pocophone F1 Battery Disconnect, Remove the protective foil: step 12, image 2 of 3 Pocophone F1 Battery Disconnect, Remove the protective foil: step 12, image 3 of 3
      Tool used on this step:
      Buy
      • Use a pair of tweezers to peel the black protective foil off the battery and logic board and remove it.
      Ask FixBot
    2. Pocophone F1 Battery Disconnect, Disconnect the battery: step 13, image 1 of 2 Pocophone F1 Battery Disconnect, Disconnect the battery: step 13, image 2 of 2
      • Use the flat end of a spudger to pry up and disconnect the battery connector.
      Ask FixBot
Dominik Schnabelrauch
266,249 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,885 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 21
All Time: 298
