Introduction
Use this guide to replace a faulty Playstation Move Motherboard.
Using a Phillips #0 screwdriver, remove the four 10mm screws located on the back of the device.
Insert the plastic opening tool at the indent.
Gently use a forward and backward motion to safely pop open the cover.
Using your hands to further pull it apart.
Using a Phillips head screwdriver, remove the 9mm screw located to the right of the battery, which is connected to the inner plastic frame.
Using the plastic opening tool carefully take out the grey cylindrical piece (vibrator) that is also attached to a wire.
Using one hand to hold the device, and the other hand to squeeze the inner plastic frame.
Remove by squeezing the inner plastic frame, lift and pull it towards you.
