Sony PlayStation Move Battery Replacement
  1. Sony PlayStation Move  Battery Replacement, Battery: step 1, image 1 of 1
    • Using a Phillips #0 screwdriver, remove the four 10mm screws from the corners of the trigger button.
  2. Sony PlayStation Move  Battery Replacement: step 2, image 1 of 3 Sony PlayStation Move  Battery Replacement: step 2, image 2 of 3 Sony PlayStation Move  Battery Replacement: step 2, image 3 of 3
    • Using a Phillips #0 screwdriver, remove the four 10mm screws located at the back of the device.
  3. Sony PlayStation Move  Battery Replacement: step 3, image 1 of 2 Sony PlayStation Move  Battery Replacement: step 3, image 2 of 2
    • Insert the plastic opening tool at the indent along the front and back surfaces of the controller.
    • Gently use a forward and backward motion to safely pop open the cover.
    • Use your hands to further pull it apart and pop it open.
  4. Sony PlayStation Move  Battery Replacement: step 4, image 1 of 2 Sony PlayStation Move  Battery Replacement: step 4, image 2 of 2
    • Once the device is opened, lift the battery out of the black plastic holder.
    • Carefully pull the battery out and ensure that it's wires are still connected to the inside.
  5. Sony PlayStation Move  Battery Replacement: step 5, image 1 of 3 Sony PlayStation Move  Battery Replacement: step 5, image 2 of 3 Sony PlayStation Move  Battery Replacement: step 5, image 3 of 3
    • Using a Phillips head screwdriver, remove the 9mm screw located to the right of the battery, which is connected to the inner plastic frame.
    • Use the plastic opening tool to carefully take out the grey cylindrical piece (vibrator) that is also attached to a wire.
  6. Sony PlayStation Move  Battery Replacement: step 6, image 1 of 2 Sony PlayStation Move  Battery Replacement: step 6, image 2 of 2
    • Gently pull out the small cylindrical grey piece (vibrator).
    • Removing this piece makes it easier to access the wire connection of the battery and remove it.
  7. Sony PlayStation Move  Battery Replacement: step 7, image 1 of 2 Sony PlayStation Move  Battery Replacement: step 7, image 2 of 2
    • Use tweezers to remove the small piece with a cylindrical top that is located to the left of the inner plastic frame.
  8. Sony PlayStation Move  Battery Replacement: step 8, image 1 of 3 Sony PlayStation Move  Battery Replacement: step 8, image 2 of 3 Sony PlayStation Move  Battery Replacement: step 8, image 3 of 3
    • Use one hand to hold the bottom of the device, and the other hand to squeeze the inner plastic frame.
    • While squeezing the inner plastic frame, pull it up and then pull it towards you to detach it.
    • While removing the frame, be extremely careful because it could damage the frame or the motherboard.
  9. Sony PlayStation Move  Battery Replacement: step 9, image 1 of 2 Sony PlayStation Move  Battery Replacement: step 9, image 2 of 2
    • Gently pull on the end of the red and black wires which is closest to the connector to disconnect the battery.
Jenelle Mohammed
217 Reputation
1 Guide authored
USF Tampa, Team 3-3, Passmore Fall 2016 Member of USF Tampa, Team 3-3, Passmore Fall 2016
USFT-PASSMORE-F16S3G3
4 Members
8 Guides authored
Past 24 Hours: 0
Past 7 Days: 21
Past 30 Days: 84
All Time: 14,323
