Introduction
This guide will show the steps to dismantle the move controller and remove the battery in order to have it replaced.
Using a Phillips #0 screwdriver, remove the four 10mm screws from the corners of the trigger button.
Using a Phillips #0 screwdriver, remove the four 10mm screws located at the back of the device.
Insert the plastic opening tool at the indent along the front and back surfaces of the controller.
Gently use a forward and backward motion to safely pop open the cover.
Use your hands to further pull it apart and pop it open.
Using a Phillips head screwdriver, remove the 9mm screw located to the right of the battery, which is connected to the inner plastic frame.
Use the plastic opening tool to carefully take out the grey cylindrical piece (vibrator) that is also attached to a wire.
Use tweezers to remove the small piece with a cylindrical top that is located to the left of the inner plastic frame.
Use one hand to hold the bottom of the device, and the other hand to squeeze the inner plastic frame.
While squeezing the inner plastic frame, pull it up and then pull it towards you to detach it.
Gently pull on the end of the red and black wires which is closest to the connector to disconnect the battery.
