Introduction
Follow this guide to replace a broken or faulty fan in your PlayStation 5 Pro. You can also use this guide to clean out a dusty or dirty fan.
If your fan isn't spinning, is spinning very slowly, or is making very loud noises, you may need to replace it.
Before purchasing a replacement fan, it's a good idea to remove your current fan and clean off any dust, dirt, hair, or grime that may have accumulated—it's possible this alone is the problem. If the fan still shows signs of being faulty after cleaning, then consider purchasing a replacement.
Shut down your PlayStation and unplug all cables and accessories.
Remove any stands supporting your console and lay it down so the right side is facing up.
Firmly pull up the front edge of the smaller, upper cover to release the clips.
Remove the cover.
Tool used on this step:Tesa 61395 Tape$8.95
Use your fingers to remove the plastic cover hiding the fan cables connector.
Gently pull the fan cables out from under their plastic clip on the frame.
Firmly grip the fan cables' white connector head and pull it straight up and out of its socket.
Tool used on this step:FixMat$36.95
Use a T8 Torx Security screwdriver to remove the four screws securing the fan:
One 31.7 mm‑long screw
Two 21.5 mm‑long screws
One 11.5 mm‑long screw
Use your fingers to grab the fan by its vents and lift it straight up to remove it.
If you're using this guide to clean your fan, use compressed air and a clean cloth to remove any dust or dirt.
3 other people completed this guide.
