PlayStation 4 WiFi Antenna Replacement
  1. PlayStation 4 WiFi Antenna Replacement, Remove Stickers: step 1, image 1 of 3 PlayStation 4 WiFi Antenna Replacement, Remove Stickers: step 1, image 2 of 3 PlayStation 4 WiFi Antenna Replacement, Remove Stickers: step 1, image 3 of 3
    • Using a dental pick or something similar, remove the three stickers on the bottom casing.
  2. PlayStation 4 WiFi Antenna Replacement, Remove Bottom Case Screws: step 2, image 1 of 2 PlayStation 4 WiFi Antenna Replacement, Remove Bottom Case Screws: step 2, image 2 of 2
    • Remove the three black screws in the bottom case using a T9 security torx bit.
  3. PlayStation 4 WiFi Antenna Replacement, Remove Bottom Case: step 3, image 1 of 3 PlayStation 4 WiFi Antenna Replacement, Remove Bottom Case: step 3, image 2 of 3 PlayStation 4 WiFi Antenna Replacement, Remove Bottom Case: step 3, image 3 of 3
    • Pull up on one side of the case, then the other then slide the case back. It will then be free from the rest of the console.
  4. PlayStation 4 WiFi Antenna Replacement, Remove Power Supply Screws: step 4, image 1 of 3 PlayStation 4 WiFi Antenna Replacement, Remove Power Supply Screws: step 4, image 2 of 3 PlayStation 4 WiFi Antenna Replacement, Remove Power Supply Screws: step 4, image 3 of 3
    • Remove the five screws that secure the power supply. There are two PH1 and three T9 torx security screws.
  5. PlayStation 4 WiFi Antenna Replacement, Remove Power Supply: step 5, image 1 of 3 PlayStation 4 WiFi Antenna Replacement, Remove Power Supply: step 5, image 2 of 3 PlayStation 4 WiFi Antenna Replacement, Remove Power Supply: step 5, image 3 of 3
    • First pull up on one side of the power supply, then pull up on the other side. Gently but firmly wiggle it out.
    • Be careful as you pull up on the power supply as it is still connected with a connector from the motherboard.
  6. PlayStation 4 WiFi Antenna Replacement, Disconnect WiFi Antenna: step 6, image 1 of 3 PlayStation 4 WiFi Antenna Replacement, Disconnect WiFi Antenna: step 6, image 2 of 3 PlayStation 4 WiFi Antenna Replacement, Disconnect WiFi Antenna: step 6, image 3 of 3
    • The power supply can lifted out and rotated down and set on the workbench.
    • Be very careful not to pull on the power supply as it will still be connected to the motherboard.
    • Use ESD-safe tweezers to carefully disconnect the wi-fi antenna by pulling it straight up.
    • Be be careful not to apply too much force on the WiFi connector as it can break off.
    • Do NOT use pliers as shown in this hastily taken photo.
    • After the WiFi cable is disconnected, de-route the cable from the two clips and under the optical drive cable.
  7. PlayStation 4 WiFi Antenna Replacement, Remove WiFi Screw & WiFi Antenna: step 7, image 1 of 3 PlayStation 4 WiFi Antenna Replacement, Remove WiFi Screw & WiFi Antenna: step 7, image 2 of 3 PlayStation 4 WiFi Antenna Replacement, Remove WiFi Screw & WiFi Antenna: step 7, image 3 of 3
    • Remove the one torx T9 security screw from the WiFi antenna located at the front of the console.
    • The WiFi Antenna can now be fully removed from the PS4.
TronicsFix
34,855 Reputation
5 Guides authored
TronicsFix Member of TronicsFix
Business
1 Member
21 Guides authored
Past 24 Hours: 30
Past 7 Days: 182
Past 30 Days: 914
All Time: 165,868
