PlayStation 4 Optical Drive Replacement
  1. PlayStation 4 Optical Drive Replacement, Remove the power supply unit: step 1, image 1 of 2 PlayStation 4 Optical Drive Replacement, Remove the power supply unit: step 1, image 2 of 2
    • Remove three 9.7 mm Torx security screws.
    • Remove two 41 mm Phillips screws and brackets.
  2. PlayStation 4 Optical Drive Replacement: step 2, image 1 of 3 PlayStation 4 Optical Drive Replacement: step 2, image 2 of 3 PlayStation 4 Optical Drive Replacement: step 2, image 3 of 3
    • Lift the power supply straight up and out of the PS4.
    • The power supply is held firmly in place by prongs on the left side. It may take multiple attempts to remove it.
    • During reassembly, ensure the prongs are aligned, then press the power supply into place.
  3. PlayStation 4 Optical Drive Replacement, Optical Drive: step 3, image 1 of 1
    • Disconnect the ribbon wire from the optical drive by pressing down on the metal release tab and gently pulling the ribbon wire. This should not require force.
  4. PlayStation 4 Optical Drive Replacement: step 4, image 1 of 1
    • Disconnect the same ribbon wire from the motherboard; making sure you're pressing down on the metal release tab and gently pulling the ribbon wire.
  5. PlayStation 4 Optical Drive Replacement: step 5, image 1 of 1
    • Remove the wifi antenna cable attached to the motherboard.
  6. PlayStation 4 Optical Drive Replacement: step 6, image 1 of 1
    • Remove the optical drive four wire plug from the motherboard by pulling straight out.
  7. PlayStation 4 Optical Drive Replacement: step 7, image 1 of 1
    • Remove the four 9mm Torx T9 screw attached to the wifi antenna and optical drive.
    • Remove the 5mm Phillips head #1 screw.
  8. PlayStation 4 Optical Drive Replacement: step 8, image 1 of 1
    • Lift up and remove the wifi antenna.
  9. PlayStation 4 Optical Drive Replacement: step 9, image 1 of 2 PlayStation 4 Optical Drive Replacement: step 9, image 2 of 2
    • The optical drive can now be lifted straight up and removed from the system.
    • Be aware that the optical drive is "married" to the motherboard. If you need to replace your optical drive you must remove the motherboard on the original optical drive and install it on the drive you intend to install in your PS4.
Robert Harvey
10,371 Reputation
5 Guides authored
Cal Poly, Team 8-12, Regan Spring 2014 Member of Cal Poly, Team 8-12, Regan Spring 2014
CPSU-REGAN-S14S8G12
5 Members
5 Guides authored
Past 24 Hours: 77
Past 7 Days: 570
Past 30 Days: 2,621
All Time: 456,138
