PlayStation 4 Fan Replacement
Video Overview
  1. PlayStation 4 Fan Replacement, Remove the upper case: step 1, image 1 of 2 PlayStation 4 Fan Replacement, Remove the upper case: step 1, image 2 of 2
    • Remove the two 9.7 mm Torx screws securing the upper case.
  2. PlayStation 4 Fan Replacement: step 2, image 1 of 3 PlayStation 4 Fan Replacement: step 2, image 2 of 3 PlayStation 4 Fan Replacement: step 2, image 3 of 3
    • Lift the upper case up and back to remove it from the PS4.
    • The upper case in held in place by plastic tabs on the front side. It will take significant force to separate them.
  3. PlayStation 4 Fan Replacement, Remove the upper EMI shield: step 3, image 1 of 2 PlayStation 4 Fan Replacement, Remove the upper EMI shield: step 3, image 2 of 2
    • Remove the twelve 9.7 mm Torx screws securing the upper EMI shield.
  4. PlayStation 4 Fan Replacement: step 4, image 1 of 3 PlayStation 4 Fan Replacement: step 4, image 2 of 3 PlayStation 4 Fan Replacement: step 4, image 3 of 3
    • This step shows you how to properly unscrew the pressure plate.
    • Remove the two 15.6 mm Phillips screws.
    • Gradually unscrew the pressure plate by turning each screw one half turn at a time.
    • Alternate between the two screws to maintain even pressure on the pressure plate.
    • Do not unscrew one side completely before unscrewing the other side or you may damage the processor.
  5. PlayStation 4 Fan Replacement: step 5, image 1 of 1
    • Remove the pressure plate.
  6. PlayStation 4 Fan Replacement: step 6, image 1 of 2 PlayStation 4 Fan Replacement: step 6, image 2 of 2
    • Remove the upper EMI shield.
  7. PlayStation 4 Fan Replacement, Remove the motherboard: step 7, image 1 of 2 PlayStation 4 Fan Replacement, Remove the motherboard: step 7, image 2 of 2
    • Insert the flat end of a spudger in between the fan cable and the motherboard.
    • Twist the spudger to lift the connector straight up and disconnect it from the motherboard.
  8. PlayStation 4 Fan Replacement: step 8, image 1 of 2 PlayStation 4 Fan Replacement: step 8, image 2 of 2
    • Grab the edge of the motherboard on the front of the PS4.
    • Lift the motherboard until the USB ports clear the PS4 case.
  9. PlayStation 4 Fan Replacement: step 9, image 1 of 3 PlayStation 4 Fan Replacement: step 9, image 2 of 3 PlayStation 4 Fan Replacement: step 9, image 3 of 3
    • Lift the motherboard out from the PS4.
    • Apply a new layer of thermal paste to the processor before installing a motherboard using this guide.
    • Failure to properly install new thermal paste will cause your PS4 to overheat.
    • Insert the I/O side of the Motherboard in first, then lower the other side in.
  10. PlayStation 4 Fan Replacement, Fan: step 10, image 1 of 1
    • Remove three, 5mm Phillips head #1 screws.
    • Lift straight up on the metal tray to remove it.
  11. PlayStation 4 Fan Replacement: step 11, image 1 of 2 PlayStation 4 Fan Replacement: step 11, image 2 of 2
    • The fan is now exposed, remove the two 9mm Phillips head #1 screws.
    • If your PS4 has a third screw at the upper right, remove it as well.
    • Lift the fan up to remove it for replacement.
Robert Harvey
10,374 Reputation
5 Guides authored
Cal Poly, Team 8-12, Regan Spring 2014 Member of Cal Poly, Team 8-12, Regan Spring 2014
CPSU-REGAN-S14S8G12
5 Members
5 Guides authored
Past 24 Hours: 111
Past 7 Days: 615
Past 30 Days: 3,024
All Time: 500,007
