Introduction
If your PS4 is running hard and constantly overheating and has led you to replacing the fan, follow the steps below. Be aware that any replacement or teardown beyond the hard drive voids the Sony warranty.
Removing the motherboard separates the original thermal paste between the processor and the heat sink. Before you reassemble your device, reapply a new layer of thermal paste. Follow this guide to learn how.
Video Overview
Remove the twelve 9.7Â mm Torx screws securing the upper EMI shield.
Remove the two 15.6Â mm Phillips screws.
Gradually unscrew the pressure plate by turning each screw one half turn at a time.
Alternate between the two screws to maintain even pressure on the pressure plate.
Insert the flat end of a spudger in between the fan cable and the motherboard.
Twist the spudger to lift the connector straight up and disconnect it from the motherboard.
Grab the edge of the motherboard on the front of the PS4.
Lift the motherboard until the USB ports clear the PS4 case.
Remove three, 5mm Phillips head #1 screws.
Lift straight up on the metal tray to remove it.
The fan is now exposed, remove the two 9mm Phillips head #1 screws.
If your PS4 has a third screw at the upper right, remove it as well.
Lift the fan up to remove it for replacement.
