Installing PlayStation 3 Slim Motherboard Assembly
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Installing PlayStation 3 Slim Motherboard Assembly, Motherboard Assembly: step 1, image 1 of 1
    • Pull the AC-In cables upward to remove the AC inlet from the lower case.
  2. Installing PlayStation 3 Slim Motherboard Assembly: step 2, image 1 of 2 Installing PlayStation 3 Slim Motherboard Assembly: step 2, image 2 of 2
    • Use the flat end of a spudger to pry both antenna connectors up from their sockets on the motherboard.
  3. Installing PlayStation 3 Slim Motherboard Assembly: step 3, image 1 of 1
    • Pull the control board ribbon cable up and out of its socket on the motherboard.
    • Remove the control board.
  4. Installing PlayStation 3 Slim Motherboard Assembly: step 4, image 1 of 1
    • Turn the PS3 over and lay it on its backside.
    • Use the flat edge of a metal spudger to pop up the small access door on the bottom cover near the front of the PS3.
    • Remove the blue Phillips screw hidden under the access door.
  5. Installing PlayStation 3 Slim Motherboard Assembly: step 5, image 1 of 1
    • Slide the hard drive bay cover toward the right side of the lower case, then pull it away from the front edge to remove it from the PS3.
  6. Installing PlayStation 3 Slim Motherboard Assembly: step 6, image 1 of 1
    • Using its attached metal handle, pull the hard drive out of its bay.
  7. Installing PlayStation 3 Slim Motherboard Assembly: step 7, image 1 of 1
    • Remove the following five screws securing the motherboard assembly to the lower case:
    • Two silver 6 mm Phillips
    • Three black 8 mm Phillips
  8. Installing PlayStation 3 Slim Motherboard Assembly: step 8, image 1 of 1
    • Lift the motherboard assembly from its front edge and remove it from the lower case, minding the antenna cable still attached to the lower case.
    • Be careful not to bend the metal antenna bodies as you lift the motherboard assembly.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 1,192
