PlayStation 3 Slim Motherboard Assembly Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. PlayStation 3 Slim Motherboard Assembly Replacement, Motherboard Assembly: step 1, image 1 of 1
    • Pull the AC-In cables upward to remove the AC inlet from the lower case.
  2. PlayStation 3 Slim Motherboard Assembly Replacement: step 2, image 1 of 2 PlayStation 3 Slim Motherboard Assembly Replacement: step 2, image 2 of 2
    • Use the flat end of a spudger to pry both antenna connectors up from their sockets on the motherboard.
  3. PlayStation 3 Slim Motherboard Assembly Replacement: step 3, image 1 of 1
    • Pull the control board ribbon cable up and out of its socket on the motherboard.
    • Remove the control board.
  4. PlayStation 3 Slim Motherboard Assembly Replacement: step 4, image 1 of 1
    • Turn the PS3 over and lay it on its backside.
    • Use the flat edge of a metal spudger to pop up the small access door on the bottom cover near the front of the PS3.
    • Remove the blue Phillips screw hidden under the access door.
  5. PlayStation 3 Slim Motherboard Assembly Replacement: step 5, image 1 of 1
    • Slide the hard drive bay cover toward the right side of the lower case, then pull it away from the front edge to remove it from the PS3.
  6. PlayStation 3 Slim Motherboard Assembly Replacement: step 6, image 1 of 1
    • Using its attached metal handle, pull the hard drive out of its bay.
  7. PlayStation 3 Slim Motherboard Assembly Replacement: step 7, image 1 of 1
    • Remove the following five screws securing the motherboard assembly to the lower case:
    • Two silver 6 mm Phillips
    • Three black 8 mm Phillips
  8. PlayStation 3 Slim Motherboard Assembly Replacement: step 8, image 1 of 1
    • Lift the motherboard assembly from its front edge and remove it from the lower case, minding the antenna cable still attached to the lower case.
    • Be careful not to bend the metal antenna bodies as you lift the motherboard assembly.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 1,192
