Introduction
Use this guide to replace your PlayStation 3 Slim's SATA hard drive with a much larger hard drive or a much faster SSD.
NOTE: Any 2.5" SATA drive with a height below 9.5mm is safe to use for replacement and is not restricted to the parts listed in this guide.
Turn the PS3 over and lay it on its backside.
Use the flat edge of a metal spudger to pop up the small access door on the bottom cover near the front of the PS3.
Remove the blue Phillips screw hidden under the access door.
Slide the hard drive bay cover toward the right side of the lower case, then pull it away from the front edge to remove it from the PS3.
