PlayStation 3 Slim Hard Drive Replacement
  1. PlayStation 3 Slim Hard Drive Replacement, Hard Drive: step 1, image 1 of 2 PlayStation 3 Slim Hard Drive Replacement, Hard Drive: step 1, image 2 of 2
    • Turn the PS3 over and lay it on its backside.
    • Use the flat edge of a metal spudger to pop up the small access door on the bottom cover near the front of the PS3.
    • Remove the blue Phillips screw hidden under the access door.
  2. PlayStation 3 Slim Hard Drive Replacement: step 2, image 1 of 1
    • Slide the hard drive bay cover toward the right side of the lower case, then pull it away from the front edge to remove it from the PS3.
  3. PlayStation 3 Slim Hard Drive Replacement: step 3, image 1 of 2 PlayStation 3 Slim Hard Drive Replacement: step 3, image 2 of 2
    • Using its attached metal handle, pull the hard drive out of its bay.
    • This is a SATA 2.5" Hard Drive. It can be swapped to another HDD or to a SSD, just make sure it meets these two specs.
  4. PlayStation 3 Slim Hard Drive Replacement, Hard Drive: step 4, image 1 of 1
    • Remove the four 4.3 mm Phillips screws securing the hard drive to its tray.
  5. PlayStation 3 Slim Hard Drive Replacement: step 5, image 1 of 2 PlayStation 3 Slim Hard Drive Replacement: step 5, image 2 of 2
    • Remove the hard drive from its tray.
Past 24 Hours: 93
Past 7 Days: 596
Past 30 Days: 2,239
All Time: 340,533
