Introduction
Replace your PlayStation 2's scratched-up or worn out top cover.
Use the flat edge of a metal spudger to pry the eight flat screw covers out.
Remove the following eight screws securing the top cover to the bottom case:
Four 55.4 mm Philips screws
Four 18.0 mm Phillips screws
Remove the four screws in the bottom of the upper portion of the block where the PS2 logo is, as well as the six screws in the bottom of the machine itself.
Peel the warranty sticker (located next to the main power switch) straight away from the case.
Lift the top cover off the bottom case.
Carefully remove the power cord that attaches the top and bottom halves by disconnecting the power cord assembly from the bottom case.
