PlayStation 2 Top Cover Replacement
  1. PlayStation 2 Top Cover Replacement, Top Cover: step 1, image 1 of 3 PlayStation 2 Top Cover Replacement, Top Cover: step 1, image 2 of 3 PlayStation 2 Top Cover Replacement, Top Cover: step 1, image 3 of 3
    • Flip the PlayStation 2 over so it lays with the bottom of the device facing upwards.
    • Use the flat edge of a metal spudger to pry the eight flat screw covers out.
    • Remove the following eight screws securing the top cover to the bottom case:
    • Four 55.4 mm Philips screws
    • Four 18.0 mm Phillips screws
  2. PlayStation 2 Top Cover Replacement: step 2, image 1 of 3 PlayStation 2 Top Cover Replacement: step 2, image 2 of 3 PlayStation 2 Top Cover Replacement: step 2, image 3 of 3
    • Remove the four screws in the bottom of the upper portion of the block where the PS2 logo is, as well as the six screws in the bottom of the machine itself.
  3. PlayStation 2 Top Cover Replacement: step 3, image 1 of 1
    • Peel the warranty sticker (located next to the main power switch) straight away from the case.
    • To avoid activating the VOID that may come up, heat it carefully to remove and replace it clean
  4. PlayStation 2 Top Cover Replacement: step 4, image 1 of 2 PlayStation 2 Top Cover Replacement: step 4, image 2 of 2
    • Flip the PlayStation 2 back to its original upside position.
    • Lift the top cover off the bottom case.
    • To facilitate the removal, it is recommended to pry open the half closer to the power switch first while rocking the top cover towards the front of the bottom case.
    • Carefully remove the power cord that attaches the top and bottom halves by disconnecting the power cord assembly from the bottom case.
jwyoung
2,809 Reputation
5 Guides authored
Cal Poly, Team 19-1, Maness Fall 2009 Member of Cal Poly, Team 19-1, Maness Fall 2009
CPSU-MANESS-F09S19G1
4 Members
34 Guides authored
Past 24 Hours: 2
Past 7 Days: 48
Past 30 Days: 154
All Time: 18,540
