Shop the Holiday Gift Guide
Philips Somneo LED Assembly Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
22
Past 30 Days:
89
All Time:
510
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
If your Philips Somneo light is faulty or not working, access the LED with this guide. For this guide, you will need a plastic opening tool/pick, a plastic and metal spudger, and a Phillips #00 screwdriver head. You will not need to do any difficult steps, but when removing the motherboard, be sure to disconnect the cables carefully.
Tools
    1. Philips Somneo LED Assembly Replacement, Antenna: step 1, image 1 of 1
      • Remove the four silicone feet on the bottom plate.
      • Remove the following Phillips screws from the bottom plate:
      • Two 9 mm screws
      • Two 13 mm screws
      Ask FixBot
    2. Philips Somneo LED Assembly Replacement: step 2, image 1 of 2 Philips Somneo LED Assembly Replacement: step 2, image 2 of 2
      • Remove the bottom plate from the device.
      Ask FixBot
    3. Philips Somneo LED Assembly Replacement: step 3, image 1 of 2 Philips Somneo LED Assembly Replacement: step 3, image 2 of 2
      • Disconnect the antenna connector by pulling it directly out of its port.
      • Remove the antenna.
      Ask FixBot
    1. Philips Somneo LED Assembly Replacement, Motherboard: step 4, image 1 of 2 Philips Somneo LED Assembly Replacement, Motherboard: step 4, image 2 of 2
      • Remove the four 9 mm Phillips screws securing the motherboard.
      Ask FixBot
    2. Philips Somneo LED Assembly Replacement: step 5, image 1 of 2 Philips Somneo LED Assembly Replacement: step 5, image 2 of 2
      • Gently pull the motherboard down until the cables are visible.
      • Take care not to strain the connected cables.
      Ask FixBot
    3. Philips Somneo LED Assembly Replacement: step 6, image 1 of 3 Philips Somneo LED Assembly Replacement: step 6, image 2 of 3 Philips Somneo LED Assembly Replacement: step 6, image 3 of 3
      • Remove each cord by gently disconnecting each connector with your hand.
      Ask FixBot
    4. Philips Somneo LED Assembly Replacement: step 7, image 1 of 3 Philips Somneo LED Assembly Replacement: step 7, image 2 of 3 Philips Somneo LED Assembly Replacement: step 7, image 3 of 3
      • Continue gently removing each cord with you hand.
      Ask FixBot
    5. Philips Somneo LED Assembly Replacement: step 8, image 1 of 2 Philips Somneo LED Assembly Replacement: step 8, image 2 of 2
      • Finish gently removing the final cord attached to the motherboard to successfully remove the motherboard.
      Ask FixBot
    1. Philips Somneo LED Assembly Replacement, LED Assembly: step 9, image 1 of 3 Philips Somneo LED Assembly Replacement, LED Assembly: step 9, image 2 of 3 Philips Somneo LED Assembly Replacement, LED Assembly: step 9, image 3 of 3
      • Use an opening pick to pry underneath the plastic covering the edges of the screen.
      • Place an opening tool in the space made between the screen and this plastic piece and pry up, working around the length of this circular piece to significantly loosen it.
      Ask FixBot
    2. Philips Somneo LED Assembly Replacement: step 10, image 1 of 2 Philips Somneo LED Assembly Replacement: step 10, image 2 of 2
      • The panel should be loosened significantly enough to be pulled off the main body, revealing the edges of the screen.
      Ask FixBot
    3. Philips Somneo LED Assembly Replacement: step 11, image 1 of 2 Philips Somneo LED Assembly Replacement: step 11, image 2 of 2
      • Remove the two 13 mm Phillips #0 screws on the bottom edges of the screen.
      • Remove the 9 mm Phillips #0 screws on the upper edge of the screen.
      Ask FixBot
    4. Philips Somneo LED Assembly Replacement: step 12, image 1 of 3 Philips Somneo LED Assembly Replacement: step 12, image 2 of 3 Philips Somneo LED Assembly Replacement: step 12, image 3 of 3
      • Remove the display assembly.
      Ask FixBot
    5. Philips Somneo LED Assembly Replacement: step 13, image 1 of 3 Philips Somneo LED Assembly Replacement: step 13, image 2 of 3 Philips Somneo LED Assembly Replacement: step 13, image 3 of 3
      • On the back of the screen, remove the four 9 mm Phillips #00 screws, disconnecting the LED assembly.
      Ask FixBot
    6. Philips Somneo LED Assembly Replacement: step 14, image 1 of 3 Philips Somneo LED Assembly Replacement: step 14, image 2 of 3 Philips Somneo LED Assembly Replacement: step 14, image 3 of 3
      • Two cables connected to the LED were once connected to the motherboard, but are still attached to the body. They are threaded through black ovals connected to the body by a hard black adhesive.
      • Using a metal spudger, scrape underneath this adhesive and pry up, freeing the cable from the body. Repeat this for the other cable to free the LED.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Author
with
Ryan Borges
213 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 22
Past 30 Days: 89
All Time: 510
