Petcube Play 2 Microphone Replacement
    1. Petcube Play 2 Microphone Replacement, Motherboard: step 1, image 1 of 3 Petcube Play 2 Microphone Replacement, Motherboard: step 1, image 2 of 3 Petcube Play 2 Microphone Replacement, Motherboard: step 1, image 3 of 3
      • Flip over the Petcube so the rubber bottom faces you.
      • Pull up the rubber layer with an iFixit opening pick to expose the screws underneath.
      Ask FixBot
    2. Petcube Play 2 Microphone Replacement: step 2, image 1 of 2 Petcube Play 2 Microphone Replacement: step 2, image 2 of 2
      • Remove the four 3.5mm screws from under the rubber cover using a Phillips #1 screwdriver.
      • The glue may cause slight resistance, but the screws should come out with minimal effort.
      Ask FixBot
    3. Petcube Play 2 Microphone Replacement: step 3, image 1 of 2 Petcube Play 2 Microphone Replacement: step 3, image 2 of 2
      • Carefully pry off the glass front panel using an opening pick or a spudger.
      • Do not force the front panel off, as it may crack and break.
      Ask FixBot
    4. Petcube Play 2 Microphone Replacement: step 4, image 1 of 3 Petcube Play 2 Microphone Replacement: step 4, image 2 of 3 Petcube Play 2 Microphone Replacement: step 4, image 3 of 3
      • Slide off the two covers, starting with the top plastic cover.
      • Slide out the internal assembly from the aluminum casing.
      Ask FixBot
    5. Petcube Play 2 Microphone Replacement: step 5, image 1 of 3 Petcube Play 2 Microphone Replacement: step 5, image 2 of 3 Petcube Play 2 Microphone Replacement: step 5, image 3 of 3
      • Once the internal assembly is removed, a brass cylinder in one corner of the cube's front face will be visible. A screw will be attached to it.
      • Remove the screw with a Phillips #1 screwdriver.
      Ask FixBot
    6. Petcube Play 2 Microphone Replacement: step 6, image 1 of 3 Petcube Play 2 Microphone Replacement: step 6, image 2 of 3 Petcube Play 2 Microphone Replacement: step 6, image 3 of 3
      • Flip the cube onto its side to locate the pull tabs.
      • Using an opening tool, lift each of the five tabs to separate the two halves of the Petcube 2.
      Ask FixBot
    7. Petcube Play 2 Microphone Replacement: step 7, image 1 of 3 Petcube Play 2 Microphone Replacement: step 7, image 2 of 3 Petcube Play 2 Microphone Replacement: step 7, image 3 of 3
      • Gently disconnect the cable connectors to separate the two halves of the device.
      • Avoid pulling on the wires to prevent damage to the connectors.
      Ask FixBot
    8. Petcube Play 2 Microphone Replacement: step 8, image 1 of 3 Petcube Play 2 Microphone Replacement: step 8, image 2 of 3 Petcube Play 2 Microphone Replacement: step 8, image 3 of 3
      • Use a Phillips #1 screwdriver to remove the two 1mm screws.
      • Carefully release each of the tabs on the sides of the cube and remove the motherboard.
      • Be gentle with the tabs. They will break under too much pressure.
      Ask FixBot
    1. Petcube Play 2 Microphone Replacement, Microphone: step 9, image 1 of 3 Petcube Play 2 Microphone Replacement, Microphone: step 9, image 2 of 3 Petcube Play 2 Microphone Replacement, Microphone: step 9, image 3 of 3
      • Use a Phillips #1 screwdriver to remove the screws from the plates behind the motherboard, separating the two plates.
      Ask FixBot
    2. Petcube Play 2 Microphone Replacement: step 10, image 1 of 2 Petcube Play 2 Microphone Replacement: step 10, image 2 of 2
      • Detach the PCB with the microphones from the plastic.
      • Using a soldering iron, desolder the microphones from the PCB.
      • Be careful! The soldering iron becomes hot! Avoid touching the device for too long, as this may damage the components.
      • To Avoid burning yourself or damaging the device, follow the IFixit soldering instructions
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Jacob Branco
291 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 24
Past 30 Days: 42
All Time: 414
