Petcube Play 2 Camera Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
17
Past 30 Days:
64
All Time:
659
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 - 50 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
If the camera of your Petcube Play 2 (identified by model number PP2OUS) is malfunctioning, use this guide to replace it.
The Petcube Play 2 comes with a built-in camera that can record and stream videos of your pet to your phone. A defective camera might lead to poor video quality, skipping, or recording failures.
Before using this guide, ensure that there are no connection issues between the Petcube, your Wi-Fi router, and your phone. The Troubleshooting Page covers connection and video quality-related issues and how to address them.
Ensure the Petcube Play 2 is turned off before beginning the replacement process.
Tools
    1. Petcube Play 2 Camera Replacement, Motherboard: step 1, image 1 of 3 Petcube Play 2 Camera Replacement, Motherboard: step 1, image 2 of 3 Petcube Play 2 Camera Replacement, Motherboard: step 1, image 3 of 3
      • Flip over the Petcube so the rubber bottom faces you.
      • Pull up the rubber layer with an iFixit opening pick to expose the screws underneath.
      Ask FixBot
    2. Petcube Play 2 Camera Replacement: step 2, image 1 of 2 Petcube Play 2 Camera Replacement: step 2, image 2 of 2
      • Remove the four 3.5mm screws from under the rubber cover using a Phillips #1 screwdriver.
      • The glue may cause slight resistance, but the screws should come out with minimal effort.
      Ask FixBot
    3. Petcube Play 2 Camera Replacement: step 3, image 1 of 2 Petcube Play 2 Camera Replacement: step 3, image 2 of 2
      • Carefully pry off the glass front panel using an opening pick or a spudger.
      • Do not force the front panel off, as it may crack and break.
      Ask FixBot
    4. Petcube Play 2 Camera Replacement: step 4, image 1 of 3 Petcube Play 2 Camera Replacement: step 4, image 2 of 3 Petcube Play 2 Camera Replacement: step 4, image 3 of 3
      • Slide off the two covers, starting with the top plastic cover.
      • Slide out the internal assembly from the aluminum casing.
      Ask FixBot
    5. Petcube Play 2 Camera Replacement: step 5, image 1 of 3 Petcube Play 2 Camera Replacement: step 5, image 2 of 3 Petcube Play 2 Camera Replacement: step 5, image 3 of 3
      • Once the internal assembly is removed, a brass cylinder in one corner of the cube's front face will be visible. A screw will be attached to it.
      • Remove the screw with a Phillips #1 screwdriver.
      Ask FixBot
    6. Petcube Play 2 Camera Replacement: step 6, image 1 of 3 Petcube Play 2 Camera Replacement: step 6, image 2 of 3 Petcube Play 2 Camera Replacement: step 6, image 3 of 3
      • Flip the cube onto its side to locate the pull tabs.
      • Using an opening tool, lift each of the five tabs to separate the two halves of the Petcube 2.
      Ask FixBot
    7. Petcube Play 2 Camera Replacement: step 7, image 1 of 3 Petcube Play 2 Camera Replacement: step 7, image 2 of 3 Petcube Play 2 Camera Replacement: step 7, image 3 of 3
      • Gently disconnect the cable connectors to separate the two halves of the device.
      • Avoid pulling on the wires to prevent damage to the connectors.
      Ask FixBot
    8. Petcube Play 2 Camera Replacement: step 8, image 1 of 3 Petcube Play 2 Camera Replacement: step 8, image 2 of 3 Petcube Play 2 Camera Replacement: step 8, image 3 of 3
      • Use a Phillips #1 screwdriver to remove the two 1mm screws.
      • Carefully release each of the tabs on the sides of the cube and remove the motherboard.
      • Be gentle with the tabs. They will break under too much pressure.
      Ask FixBot
    1. Petcube Play 2 Camera Replacement, Camera: step 9, image 1 of 2 Petcube Play 2 Camera Replacement, Camera: step 9, image 2 of 2
      • Use a pair of tweezers to firmly grip the sides of the connector and pull straight away from the socket. Hold the tweezers closer to the connector to get a better grip.
      • If you're having trouble, try rocking the connector side-to-side to loosen it.
      • You can insert the arms of a pair of sharp tweezers into the cutouts and gently push the connector out of its socket.
      • To reconnect the cable, insert the connector into its socket and push on the edges until it's fully seated.
      Ask FixBot
    2. Petcube Play 2 Camera Replacement: step 10, image 1 of 3 Petcube Play 2 Camera Replacement: step 10, image 2 of 3 Petcube Play 2 Camera Replacement: step 10, image 3 of 3
      • Use the Phillips #00 screwdriver to remove the three 1 mm screws securing the camera to the motherboard.
      • Remove the camera from the motherboard.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
JoshBerm
135 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 17
Past 30 Days: 64
All Time: 659
