Introduction
This guide will disassemble the device to the point where the CD tray unit can be replaced with a new one.
Using a Phillips screwdriver, remove the eight 9.5 mm screws on the left and right sides of the device.
Lift the top gently but firmly from the back of the device. Allow it to rest on the back without reattaching it.
Lift up the top while firmly sliding it towards the back of the device.
The next step is a zoom-in of the indicated area.
Using forceps or fingers, remove the small black wire indicated.
Grip the wire near its base and pull gently but firmly until it pops out of the slot.
This step deals with the indicated area of the device.
Lift the indicated tabs out until the restraint looks like the final picture.
Gently pull on the cord until it comes free of the attachment.
The top section of the device should now be free of the body. Place it aside in a safe place.
This step deals with the indicated portion of the the device.
Lift the indicated tabs out until they look like the final picture.
Gently pull on the cord until it comes free of its restraint.
Neither of the indicated cords have restraints on them like the previous ones. Use tweezers or fingers to pull firmly on the base of each cord until it comes free.
Use tweezers or fingers and firmly pull straight out on the cord until it comes free.
Using tweezers or fingers, lift gently on the tab indicated to free the front from the body of the device.
Rotate device 180 degrees and repeat for other side.
Rotate the front slightly forward to keep the tabs from re-engaging on their hooks.
Wiggle the front gently while pulling it forward until it comes free of the body of the device.
Using tweezers or fingers, pull gently but firmly on the base of the cord until it comes free of its slot.
Lift the body directly up off of the base and place aside.
Note the proper locations of the various tabs in the last picture.
Lift the CD Tray Unit off of the bottom of the device and replace with new unit.
When placing the new unit in, verify that the indicated pin is in its proper slot before putting the screws back on.
