Installing Panasonic SA-PM17 CD Tray Unit
  1. Installing Panasonic SA-PM17 CD Tray Unit, Disassembling front of the Panasonic SA-PM17: step 1, image 1 of 2 Installing Panasonic SA-PM17 CD Tray Unit, Disassembling front of the Panasonic SA-PM17: step 1, image 2 of 2
    • Using a Phillips screwdriver, remove the eight 9.5 mm screws on the left and right sides of the device.
  2. Installing Panasonic SA-PM17 CD Tray Unit: step 2, image 1 of 1
    • Remove these seven 11.5 mm screws and place aside.
  3. Installing Panasonic SA-PM17 CD Tray Unit: step 3, image 1 of 1
    • Lift the right side off of the device and place aside.
    • Repeat for left side.
  4. Installing Panasonic SA-PM17 CD Tray Unit: step 4, image 1 of 1
    • Lift the top gently but firmly from the back of the device. Allow it to rest on the back without reattaching it.
    • Do not pull the top too far as there are wires attached to it.
  5. Installing Panasonic SA-PM17 CD Tray Unit: step 5, image 1 of 2 Installing Panasonic SA-PM17 CD Tray Unit: step 5, image 2 of 2
    • Gently lift up on the indicated tabs to disengage them from the hooks holding them in place.
  6. Installing Panasonic SA-PM17 CD Tray Unit: step 6, image 1 of 1
    • Lift up the top while firmly sliding it towards the back of the device.
    • Do not lift the top up too high as there are cords that need to be detached before the top can be removed.
    • The next step is a zoom-in of the indicated area.
  7. Installing Panasonic SA-PM17 CD Tray Unit: step 7, image 1 of 1
    • Using forceps or fingers, remove the small black wire indicated.
    • Grip the wire near its base and pull gently but firmly until it pops out of the slot.
  8. Installing Panasonic SA-PM17 CD Tray Unit: step 8, image 1 of 3 Installing Panasonic SA-PM17 CD Tray Unit: step 8, image 2 of 3 Installing Panasonic SA-PM17 CD Tray Unit: step 8, image 3 of 3
    Tool used on this step:
    Buy
    • This step deals with the indicated area of the device.
    • Using fingers or tweezers, lift the indicated tabs out until the cord's restraint looks like the final picture.
    • Gently pull on the cord near its base until it comes free of the restraint.
  9. Installing Panasonic SA-PM17 CD Tray Unit: step 9, image 1 of 3 Installing Panasonic SA-PM17 CD Tray Unit: step 9, image 2 of 3 Installing Panasonic SA-PM17 CD Tray Unit: step 9, image 3 of 3
    • Lift the indicated tabs out until the restraint looks like the final picture.
    • Gently pull on the cord until it comes free of the attachment.
    • The top section of the device should now be free of the body. Place it aside in a safe place.
  10. Installing Panasonic SA-PM17 CD Tray Unit: step 10, image 1 of 3 Installing Panasonic SA-PM17 CD Tray Unit: step 10, image 2 of 3 Installing Panasonic SA-PM17 CD Tray Unit: step 10, image 3 of 3
    • This step deals with the indicated portion of the the device.
    • Lift the indicated tabs out until they look like the final picture.
    • Gently pull on the cord until it comes free of its restraint.
  11. Installing Panasonic SA-PM17 CD Tray Unit: step 11, image 1 of 3 Installing Panasonic SA-PM17 CD Tray Unit: step 11, image 2 of 3 Installing Panasonic SA-PM17 CD Tray Unit: step 11, image 3 of 3
    • Neither of the indicated cords have restraints on them like the previous ones. Use tweezers or fingers to pull firmly on the base of each cord until it comes free.
  12. Installing Panasonic SA-PM17 CD Tray Unit: step 12, image 1 of 2 Installing Panasonic SA-PM17 CD Tray Unit: step 12, image 2 of 2
    • Use tweezers or fingers and firmly pull straight out on the cord until it comes free.
  13. Installing Panasonic SA-PM17 CD Tray Unit: step 13, image 1 of 3 Installing Panasonic SA-PM17 CD Tray Unit: step 13, image 2 of 3 Installing Panasonic SA-PM17 CD Tray Unit: step 13, image 3 of 3
    • Using tweezers or fingers, lift gently on the tab indicated to free the front from the body of the device.
    • Rotate device 180 degrees and repeat for other side.
    • Rotate the front slightly forward to keep the tabs from re-engaging on their hooks.
  14. Installing Panasonic SA-PM17 CD Tray Unit: step 14, image 1 of 1
    • Wiggle the front gently while pulling it forward until it comes free of the body of the device.
  15. Installing Panasonic SA-PM17 CD Tray Unit, CD Tray Unit: step 15, image 1 of 2 Installing Panasonic SA-PM17 CD Tray Unit, CD Tray Unit: step 15, image 2 of 2
    • Using tweezers or fingers, pull gently but firmly on the base of the cord until it comes free of its slot.
  16. Installing Panasonic SA-PM17 CD Tray Unit: step 16, image 1 of 2 Installing Panasonic SA-PM17 CD Tray Unit: step 16, image 2 of 2
    • Using a philips screwdriver, remove the four 9.5 mm screws indicated and place aside.
  17. Installing Panasonic SA-PM17 CD Tray Unit: step 17, image 1 of 3 Installing Panasonic SA-PM17 CD Tray Unit: step 17, image 2 of 3 Installing Panasonic SA-PM17 CD Tray Unit: step 17, image 3 of 3
    • Lift the body directly up off of the base and place aside.
    • Note the proper locations of the various tabs in the last picture.
  18. Installing Panasonic SA-PM17 CD Tray Unit: step 18, image 1 of 3 Installing Panasonic SA-PM17 CD Tray Unit: step 18, image 2 of 3 Installing Panasonic SA-PM17 CD Tray Unit: step 18, image 3 of 3
    • Remove the two 9.5 mm screws indicated using an extended screwdriver.
    • Use a flashlight to view the screw on the left.
  19. Installing Panasonic SA-PM17 CD Tray Unit: step 19, image 1 of 2 Installing Panasonic SA-PM17 CD Tray Unit: step 19, image 2 of 2
    • Lift the CD Tray Unit off of the bottom of the device and replace with new unit.
    • When placing the new unit in, verify that the indicated pin is in its proper slot before putting the screws back on.
NathanB
418 Reputation
5 Guides authored
Cal Poly, Team 4-1, Regan Spring 2011 Member of Cal Poly, Team 4-1, Regan Spring 2011
CPSU-REGAN-S11S4G1
3 Members
5 Guides authored
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 41
All Time: 17,276
