iMac G3 Model M4984 Video Ram Replacement
Views: 9.7K
View statistics:
Past 24 Hours:
4
Past 7 Days:
32
Past 30 Days:
128
All Time:
9,693
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 7
7 people have marked this guide "completed." Will you be next?
Favorites: 6
6 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 15 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
The iMac G3 had onboard video which usually means no upgrade-ability. The iMac developers found a way to allow video upgrade-ability (sort of); they built 2MB on to the logic board to power the ATI 3D Rage Pro Turbo PCI, and added a video ram DIMM slot on the motherboard allowing users to upgrade their video ram using proprietary Apple DIMMs.
Tools
    1. iMac G3 Model M4984 Video Ram Replacement, Logic Board: step 1, image 1 of 1
      • The iMac G3. This was a great computer for the time, and had plenty of features.
      Ask FixBot
    2. iMac G3 Model M4984 Video Ram Replacement: step 2, image 1 of 1
      • Start by flipping the iMac upside-down. It may help to lay it on a towel, so you don't damage the screen, or scratch the face.
      Ask FixBot
    3. iMac G3 Model M4984 Video Ram Replacement: step 3, image 1 of 3 iMac G3 Model M4984 Video Ram Replacement: step 3, image 2 of 3 iMac G3 Model M4984 Video Ram Replacement: step 3, image 3 of 3
      • Remove this Phillips screw.
      • Using a flathead screwdriver, work your way around the bottom cover, until it comes off.
      • Then, lift the bottom cover up and out, and set it aside.
      Ask FixBot
    4. iMac G3 Model M4984 Video Ram Replacement: step 4, image 1 of 3 iMac G3 Model M4984 Video Ram Replacement: step 4, image 2 of 3 iMac G3 Model M4984 Video Ram Replacement: step 4, image 3 of 3
      • Now, remove the DB-15 Video connector from the logic board.
      • It may be helpful to use a Phillips screwdriver to remove the thumbscrews.
      Ask FixBot
    5. iMac G3 Model M4984 Video Ram Replacement: step 5, image 1 of 3 iMac G3 Model M4984 Video Ram Replacement: step 5, image 2 of 3 iMac G3 Model M4984 Video Ram Replacement: step 5, image 3 of 3
      • Remove the power cable from the logic board assembly.
      Ask FixBot
    6. iMac G3 Model M4984 Video Ram Replacement: step 6, image 1 of 2 iMac G3 Model M4984 Video Ram Replacement: step 6, image 2 of 2
      • Remove the front panel connector. (You may also need to remove an additional screw that connects the front panel connector to the logic board assembly).
      Ask FixBot
    7. iMac G3 Model M4984 Video Ram Replacement: step 7, image 1 of 3 iMac G3 Model M4984 Video Ram Replacement: step 7, image 2 of 3 iMac G3 Model M4984 Video Ram Replacement: step 7, image 3 of 3
      • Now, remove these Phillips screws.
      • Now, grab the logic board assembly by the piece of plastic, and lift it out.
      Ask FixBot
    8. iMac G3 Model M4984 Video Ram Replacement: step 8, image 1 of 1
      • The logic board assembly. This is the heart of the computer, it contains the motherboard, CPU, RAM, V-RAM, PRAM battery, the hard drive, and the optical drive.
      Ask FixBot
    1. iMac G3 Model M4984 Video Ram Replacement, Video Ram: step 9, image 1 of 2 iMac G3 Model M4984 Video Ram Replacement, Video Ram: step 9, image 2 of 2
      • The Video-RAM DIMM slot is located on top of the logic board. Most people confuse this with the system RAM which is hidden under the CPU Shield.
      • The GPU: an ATI 3D Rage Pro Turbo PCI with 2MB onboard + the video RAM DIMM:
      • The Video RAM DIMM:
      Ask FixBot
    2. iMac G3 Model M4984 Video Ram Replacement: step 10, image 1 of 3 iMac G3 Model M4984 Video Ram Replacement: step 10, image 2 of 3 iMac G3 Model M4984 Video Ram Replacement: step 10, image 3 of 3
      • To remove the V-RAM, push the retaining tabs out, and the DIMM should pop up, then pull it out.
      • The 2MB of V-RAM soldered to the logic board:
      • According to what I've read, the iMac will support 10MB Total V-RAM, 2MB onboard, 8MB DIMM.
      Ask FixBot
7 other people completed this guide.
Chris Green
38,466 Reputation
49 Guides authored
Master Techs Member of Master Techs
Community
336 Members
8,282 Guides authored
1 Guide Comment
where can I buy a 8mb video ram chip
Nicholas - Reply Share
Past 24 Hours: 4
Past 7 Days: 32
Past 30 Days: 128
All Time: 9,693
