Ozeri Pronto ZK14-S Button Replacement
    1. Ozeri Pronto ZK14-S Button Replacement, Panel Removal: step 1, image 1 of 2 Ozeri Pronto ZK14-S Button Replacement, Panel Removal: step 1, image 2 of 2
      • Twist the plastic plate slowly to the left to pull it away.
      Ask FixBot
    2. Ozeri Pronto ZK14-S Button Replacement: step 2, image 1 of 1
      • Lift up the sticker at the bottom where the “Ozeri” logo is to reveal a screw.
      • The sticker does not need to be completely removed.
      Ask FixBot
    3. Ozeri Pronto ZK14-S Button Replacement: step 3, image 1 of 1
      • Using a 2.0 Flathead screwdriver, remove the 9.50 mm Phillips head screw under the sticker.
      Ask FixBot
    4. Ozeri Pronto ZK14-S Button Replacement: step 4, image 1 of 2 Ozeri Pronto ZK14-S Button Replacement: step 4, image 2 of 2
      • Using a 2.0 Flathead screwdriver, remove the two 18.76 mm Phillips head screws in the plate stand.
      Ask FixBot
    5. Ozeri Pronto ZK14-S Button Replacement: step 5, image 1 of 2 Ozeri Pronto ZK14-S Button Replacement: step 5, image 2 of 2
      • Using a 2.0 Flathead screwdriver, remove the 9.44 mm Phillips head screw on the edge opposite to the LCD screen.
      Ask FixBot
    6. Ozeri Pronto ZK14-S Button Replacement: step 6, image 1 of 1
      • Turn the device over so the back panel is facing up.
      Ask FixBot
    7. Ozeri Pronto ZK14-S Button Replacement: step 7, image 1 of 1
      • Using the iFixit opening tool, pry off the two rubber stubs on the right side and the two rubber stubs on the left side of the bottom of the device.
      Ask FixBot
    8. Ozeri Pronto ZK14-S Button Replacement: step 8, image 1 of 1
      • Using a 2.0 Flathead screwdriver, remove the four 9.46 mm Phillips head screws that were under the rubber stubs.
      Ask FixBot
    9. Ozeri Pronto ZK14-S Button Replacement: step 9, image 1 of 2 Ozeri Pronto ZK14-S Button Replacement: step 9, image 2 of 2
      • Pry apart the two panels to separate them from each other.
      • Flip the device over so the LCD is facing up. Flip the front panel over on its side.
      • Be careful when separating the panels to avoid damaging the wires they are connected by.
      Ask FixBot
    1. Ozeri Pronto ZK14-S Button Replacement, Button: step 10, image 1 of 2 Ozeri Pronto ZK14-S Button Replacement, Button: step 10, image 2 of 2
      Tool used on this step:
      Flathead 3/32" or 2.5 mm Screwdriver
      $5.49
      Buy
      • Using a 2.0 Flathead screwdriver, remove the two 7.34 mm screws on the smaller motherboards.
      Ask FixBot
    2. Ozeri Pronto ZK14-S Button Replacement: step 11, image 1 of 2 Ozeri Pronto ZK14-S Button Replacement: step 11, image 2 of 2
      • Desolder the four posts in the center of the motherboard.
      • Caution: The tip of the soldering iron will be very hot
      Ask FixBot
    3. Ozeri Pronto ZK14-S Button Replacement: step 12, image 1 of 2 Ozeri Pronto ZK14-S Button Replacement: step 12, image 2 of 2
      • Desolder the two clips in the center of the motherboard.
      • Repeat steps 13 and 14 to remove the other button from its motherboard.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Oneika White
726 Reputation
4 Guides authored
USF Tampa, Team 1-4, Leahy Fall 2015 Member of USF Tampa, Team 1-4, Leahy Fall 2015
USFT-LEAHY-F15S1G4
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 28
Past 30 Days: 89
All Time: 1,526
