OnePlus Nord N200 Midframe Replacement
    1. OnePlus Nord N200 Midframe Replacement, Back Cover: step 1, image 1 of 3 OnePlus Nord N200 Midframe Replacement, Back Cover: step 1, image 2 of 3 OnePlus Nord N200 Midframe Replacement, Back Cover: step 1, image 3 of 3
      • Due to its surface, the suction tool won't hold onto the phone's rear glass. A thin slicing tool is required.
      • Insert the Jimmy into the seam between the rear glass and the midframe at the bottom edge of the phone to create a gap.
      • This may require some force.
      • Leave the Jimmy in place for a few seconds to prevent the adhesive from resealing.
      Ask FixBot
    2. OnePlus Nord N200 Midframe Replacement: step 2, image 1 of 3 OnePlus Nord N200 Midframe Replacement: step 2, image 2 of 3 OnePlus Nord N200 Midframe Replacement: step 2, image 3 of 3
      • Insert an iFixit opening pick into the gap you created with the Jimmy.
      • Slide the Jimmy around the phone to slice the adhesive.
      • Insert a second iFixit opening pick at the spot you have sliced open to keep it open.
      Ask FixBot
    3. OnePlus Nord N200 Midframe Replacement: step 3, image 1 of 3 OnePlus Nord N200 Midframe Replacement: step 3, image 2 of 3 OnePlus Nord N200 Midframe Replacement: step 3, image 3 of 3
      • Slide the iFixit opening pick along the top edge to slice the adhesive.
      • Start prying the back plate off the phone.
      Ask FixBot
    4. OnePlus Nord N200 Midframe Replacement: step 4, image 1 of 3 OnePlus Nord N200 Midframe Replacement: step 4, image 2 of 3 OnePlus Nord N200 Midframe Replacement: step 4, image 3 of 3
      • Remove the back cover.
      Ask FixBot
    1. OnePlus Nord N200 Midframe Replacement, Midframe: step 5, image 1 of 3 OnePlus Nord N200 Midframe Replacement, Midframe: step 5, image 2 of 3 OnePlus Nord N200 Midframe Replacement, Midframe: step 5, image 3 of 3
      • Use a Phillips #00 screwdriver to remove the sixteen 3.6 mm-long screws securing the midframe.
      • The orange circle represents a hidden screw that also needs to be screwed out. (At first glance it may not look like a screw).
      Ask FixBot
    2. OnePlus Nord N200 Midframe Replacement: step 6, image 1 of 3 OnePlus Nord N200 Midframe Replacement: step 6, image 2 of 3 OnePlus Nord N200 Midframe Replacement: step 6, image 3 of 3
      • Gently insert the Jimmy to create a gap between the midframe and the top of components in the bottom case.
      • Slide an opening pick around the edge of the midframe to slice the adhesive.
      • Use the Jimmy to pry off the midframe of the phone.
      Ask FixBot
    3. OnePlus Nord N200 Midframe Replacement: step 7, image 1 of 3 OnePlus Nord N200 Midframe Replacement: step 7, image 2 of 3 OnePlus Nord N200 Midframe Replacement: step 7, image 3 of 3
      • Use your hands to finish prying open the midframe off the phone.
      • Watch out for the fingerprint reader cable when taking off the back tray as it is still connected. If you are not careful, it could be damaged.
      • Pull the midframe off of the phone and lay it to the side of the phone.
      Ask FixBot
    4. OnePlus Nord N200 Midframe Replacement: step 8, image 1 of 3 OnePlus Nord N200 Midframe Replacement: step 8, image 2 of 3 OnePlus Nord N200 Midframe Replacement: step 8, image 3 of 3
      • Place a spudger or an opening tool under the connector's edge and pry straight up to disconnect the fingerprint cable connector.
      • Move the fingerprint reader cable to the side along with the midframe.
      Ask FixBot
    5. OnePlus Nord N200 Midframe Replacement: step 9, image 1 of 1
      • Remove the midframe.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order.Take your e-waste to an R2 or e-Stewards certified recycler.
Fabrise Niyonkuru
1,138 Reputation
9 Guides authored
UMass Dartmouth, Team 1-1, Konn Spring 2024 Member of UMass Dartmouth, Team 1-1, Konn Spring 2024
UMASSD-KONN-S24S1G1
4 Members
108 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 38
All Time: 645
