Community-Contributed Guide
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Needs More Images
A few more images would make this guide's procedures crystal clear.
Introduction
Go to step 1 ↓If your OnePlus 12 back glass is damaged or scratched, or you need to access the internal components of your phone, follow this simple guide to remove the back glass.
Before you begin, make sure that your phone is powered off and unplugged from the charger.
Parts
Tools
Ensure the phone is powered off and placed with the back glass facing towards you on a stable surface.
Tool used on this step:Jimmy$7.95
Insert a Jimmy into the seam of the back glass to lift it slightly. Try to reduce pressure on any single spot of the glass to avoid cracking it.
Insert a plastic card underneath the small gap created on the back glass and gently glide the card under the lifted glass.
Remove the back glass from the phone by working your way around the glass slowly. You may need to re-heat after a while to keep the glue soft. Otherwise, you may shatter the glass.
