Introduction
The Port Cover helps preventing water splashing inside the charging and AUX port. It is important to keep the cover in good shape to prevent damaging the internal components.
Flip the device over so the front of the speaker is facing down. Make sure to place the speaker on a flat surface
Use your left hand to pull while at the same time use the tweezers to compress the stem, carefully remove the port cover from the device.
