Omaker M4 Motherboard Replacement
  1. Omaker M4 Motherboard Replacement, Back Case: step 1, image 1 of 1
    • Flip the device over so the front of the speaker is facing down. Make sure to place the speaker on a flat surface
  2. Omaker M4 Motherboard Replacement: step 2, image 1 of 2 Omaker M4 Motherboard Replacement: step 2, image 2 of 2
    • Use a T6 Torx screwdriver to remove the four 9mm screws from the back of the device.
  3. Omaker M4 Motherboard Replacement: step 3, image 1 of 2 Omaker M4 Motherboard Replacement: step 3, image 2 of 2
    • Use a magnet to remove the screws after unscrewing them and place them aside.
  4. Omaker M4 Motherboard Replacement: step 4, image 1 of 1
    • Carefully remove the back cover without breaking the battery wire.
  5. Omaker M4 Motherboard Replacement: step 5, image 1 of 2 Omaker M4 Motherboard Replacement: step 5, image 2 of 2
    • Remove the end of the battery connection from the motherboard by holding the end of the wire and carefully pulling it out of the socket using tweezers.
    • The battery is still attached to the back cover.
  6. Omaker M4 Motherboard Replacement, Motherboard: step 6, image 1 of 2 Omaker M4 Motherboard Replacement, Motherboard: step 6, image 2 of 2
    • Remove the mic wire by carefully pulling the plug out of the socket.
  7. Omaker M4 Motherboard Replacement: step 7, image 1 of 1
    • Remove the speaker wire by carefully pulling the plug out of the socket on the motherboard.
  8. Omaker M4 Motherboard Replacement: step 8, image 1 of 2 Omaker M4 Motherboard Replacement: step 8, image 2 of 2
    • Use Phillips PH00 screwdriver to remove the three screws holding the motherboard in place.
  9. Omaker M4 Motherboard Replacement: step 9, image 1 of 2 Omaker M4 Motherboard Replacement: step 9, image 2 of 2
    • Remove the screws using the screwdriver.
    • Since the screws that hold the motherboard in place are smaller, the screwdriver is able to pick them up.
  10. Omaker M4 Motherboard Replacement: step 10, image 1 of 2 Omaker M4 Motherboard Replacement: step 10, image 2 of 2
    • Carefully remove the motherboard with your hand by lifting it from the device.
[deleted]
679 Reputation
4 Guides authored
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 13
All Time: 1,157
