Olympus Tough TG-1 Lens Box Replacement
  1. Olympus Tough TG-1 Lens Box Replacement, Top of Camera: step 1, image 1 of 1
    • The top of the camera does not contain screws. You do not need to remove anything from the top of the camera.
  2. Olympus Tough TG-1 Lens Box Replacement, Plug Side: step 2, image 1 of 3 Olympus Tough TG-1 Lens Box Replacement, Plug Side: step 2, image 2 of 3 Olympus Tough TG-1 Lens Box Replacement, Plug Side: step 2, image 3 of 3
    • Remove the two 5 mm screws on the side of the camera with the plug.
    • Open the compartment door and remove both 6 cm screws inside of the compartment door. This will allow you to remove the tan piece held by the screws.
  3. Olympus Tough TG-1 Lens Box Replacement, Bottom: step 3, image 1 of 1
    • Turn the camera so that you are looking at the bottom of the camera.
    • Remove the two 4 mm screws from the bottom of the camera.
    • The screws are different. The rear screw is has an unthreaded shank to locate the outer shell while screwing into the inner frame.
  4. Olympus Tough TG-1 Lens Box Replacement, Front Panel: step 4, image 1 of 3 Olympus Tough TG-1 Lens Box Replacement, Front Panel: step 4, image 2 of 3 Olympus Tough TG-1 Lens Box Replacement, Front Panel: step 4, image 3 of 3
    • Use the plastic opening tool to remove both components of the front panel. This includes the black part on the outside of the front panel and the main silver panel.
    • Once every screw and panel is removed, you can replace the backplate to make your camera weatherproof again.
  5. Olympus Tough TG-1 Lens Box Replacement, Opening the Internal Case: step 5, image 1 of 3 Olympus Tough TG-1 Lens Box Replacement, Opening the Internal Case: step 5, image 2 of 3 Olympus Tough TG-1 Lens Box Replacement, Opening the Internal Case: step 5, image 3 of 3
    • Using the plastic opening tools, carefully open the case.
    • Do not tear the white circuit ribbon.
  6. Olympus Tough TG-1 Lens Box Replacement, Opening the Screen's Protective Cover: step 6, image 1 of 3 Olympus Tough TG-1 Lens Box Replacement, Opening the Screen's Protective Cover: step 6, image 2 of 3 Olympus Tough TG-1 Lens Box Replacement, Opening the Screen's Protective Cover: step 6, image 3 of 3
    • Using the screwdriver, remove the ten 3mm anchor screws.
    • Using the plastic opening tool, open the protective cover so that the screen is exposed.
  7. Olympus Tough TG-1 Lens Box Replacement, Unclipping the Screen from the Circuit Ribbon: step 7, image 1 of 1
    • Carefully unclip the screen from its circuit ribbon.
  8. Olympus Tough TG-1 Lens Box Replacement, Lens Box: step 8, image 1 of 1
    • Locate the lens box attached to the motherboard
  9. Olympus Tough TG-1 Lens Box Replacement: step 9, image 1 of 3 Olympus Tough TG-1 Lens Box Replacement: step 9, image 2 of 3 Olympus Tough TG-1 Lens Box Replacement: step 9, image 3 of 3
    • Lift copper foiled ribbon away from lens box.
    • Detach box by unclipping ribbons attached to the mother board.
    • Lift box out of camera.
Richard Yacobellis
225 Reputation
2 Guides authored
USF Tampa, Team 4-6, Brown Winter 2015 Member of USF Tampa, Team 4-6, Brown Winter 2015
USFT-BROWN-W15S4G6
4 Members
12 Guides authored
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 18
All Time: 1,425
