Introduction
Removal of the front plate to get into the logic board, lens, etc.
Turn the camera so the USB, AV and DC in/out rubber plate it facing you.
Lift the rubber plate exposing the ports beneath.
Use a flathead screwdriver or another flat opening tool to pry the the faceplate from the whole device.
Pull off the faceplate revealing the inside of the camera.
Be careful because there is a connector that goes from the faceplate to the motherboard and if that line disconnects the camera will not power on through the on and off switch anymore.
