Olympus D590 Face Plate Replacement
  1. Olympus D590 Face Plate Replacement, Face Plate: step 1, image 1 of 1
    • Flip camera so you are looking at the bottom.
    • Unscrew all 5 base plate screws.
  2. Olympus D590 Face Plate Replacement: step 2, image 1 of 1
    • Lift open retainer clip by sliding the clip to the left and letting the clip pop up.
  3. Olympus D590 Face Plate Replacement: step 3, image 1 of 1
    • Unscrew 1 screw located next to the battery slot.
  4. Olympus D590 Face Plate Replacement: step 4, image 1 of 1
    • Turn the camera so the USB, AV and DC in/out rubber plate it facing you.
    • Lift the rubber plate exposing the ports beneath.
  5. Olympus D590 Face Plate Replacement: step 5, image 1 of 1
    • Unscrew the 2 screws next to the USB and AC ports.
  6. Olympus D590 Face Plate Replacement: step 6, image 1 of 1
    • Use a flathead screwdriver or another flat opening tool to pry the the faceplate from the whole device.
  7. Olympus D590 Face Plate Replacement: step 7, image 1 of 1
    • Pull off the faceplate revealing the inside of the camera.
    • Be careful because there is a connector that goes from the faceplate to the motherboard and if that line disconnects the camera will not power on through the on and off switch anymore.
Katie
31 Reputation
3 Guides authored
Cal Poly, Team 28-23, Regan Spring 2010 Member of Cal Poly, Team 28-23, Regan Spring 2010
CPSU-REGAN-S10S28G23
4 Members
14 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 1,615
