Shop the Holiday Gift Guide
OVNS Firework Refill Technique
View statistics:
Past 24 Hours:
4
Past 7 Days:
42
Past 30 Days:
89
All Time:
98
Comments: 2
2 comments on steps.
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Easy
Community-Contributed Guide
Introduction
Go to step 1 ↓
Although this vape is marketed as disposable, in reality it works quite well once you refill it with your favorite ejuice. Most Salt Nic liquids will work fine in it at a substantial discount from purchasing a new disposable vape.
Three or four refills are all that are recommended; after that the heater coils get too gummed up with carbon and the cotton gets burnt, resulting in bad flavor and poor vapor production.
If you're considering refilling your vape for the first time, be sure to stop using it just as soon as you start tasting a burnt flavor. A couple of pulls that taste burnt won't hurt anything, but if you continue you'll burn the cotton and possibly burn out a coil.
Note that unlike the Geek Bar Pulse vape, there is no shortcut refill technique for this vape. Even with the mouthpiece removed, there is yet another seal preventing access to the absorbent foam, so the covers must be remove to be able to refill this vape.
Tools
    1. OVNS Firework Refill Technique, Remove the Mouthpiece: step 1, image 1 of 2 OVNS Firework Refill Technique, Remove the Mouthpiece: step 1, image 2 of 2
      • Grasp the mouthpiece with a pair of pliers.
      • Give it a good, solid twist, left or right doesn't matter.
      • The pliers won't damage the silicone coating on the mouthpiece, but faint marks may be visible.
      Ask FixBot
    2. OVNS Firework Refill Technique, The Mouthpiece Seal: step 2, image 1 of 3 OVNS Firework Refill Technique, The Mouthpiece Seal: step 2, image 2 of 3 OVNS Firework Refill Technique, The Mouthpiece Seal: step 2, image 3 of 3
      • If the mouthpiece seal came off with the mouthpiece, good, because you'll need to take it off anyway.
      • Use your tweezers to take out the seal and set it aside.
      • The rim around the top goes toward the mouthpiece.
      Ask FixBot
    3. OVNS Firework Refill Technique, Replacing the Mouthpiece: step 3, image 1 of 2 OVNS Firework Refill Technique, Replacing the Mouthpiece: step 3, image 2 of 2
      • Note that the mouthpiece has a tab that only allows it to be mounted in one orientation. The arrow here points to the one you'll need to match up with on the case.
      • Here you can see inside the case where the tab on the mouthpiece lines up.
      Ask FixBot
    4. OVNS Firework Refill Technique, Remove the Power Button: step 4, image 1 of 3 OVNS Firework Refill Technique, Remove the Power Button: step 4, image 2 of 3 OVNS Firework Refill Technique, Remove the Power Button: step 4, image 3 of 3
      • Turn the power switch to the Off position; no air holes should be visible.
      • Use your opening tool to lever the power button up. It is only pressed on; there are no adhesives or clips to deal with.
      • Remove the power button.
      Ask FixBot
    5. OVNS Firework Refill Technique, Remove the rear cover: step 5, image 1 of 2 OVNS Firework Refill Technique, Remove the rear cover: step 5, image 2 of 2
      • The rear cover (the colored part) is clipped on, but the clips are tricky to undo. Start with the top edge and pry it up with your metal opening tool.
      • In the gap you can now see on the side, slip in an opening pick to keep it open.
      Ask FixBot
    6. OVNS Firework Refill Technique: step 6, image 1 of 2 OVNS Firework Refill Technique: step 6, image 2 of 2
      • Now repeat the previous step on the bottom corner of the cover.
      Ask FixBot
    7. OVNS Firework Refill Technique: step 7, image 1 of 2 OVNS Firework Refill Technique: step 7, image 2 of 2
      • Flip the vape over and pry up the bottom corner of the cover.
      • Add an opening pick.
      Ask FixBot
    8. OVNS Firework Refill Technique: step 8, image 1 of 2 OVNS Firework Refill Technique: step 8, image 2 of 2
      • Finally, the upper corner gets the same treatment.
      • Aaand, one final pick.
      Ask FixBot
    9. OVNS Firework Refill Technique: step 9, image 1 of 2 OVNS Firework Refill Technique: step 9, image 2 of 2
      • There are also internal clips along the rear side that are still holding the cover in place. It just takes a bit of force to pop it off. Grasp the long edge of the cover and pull hard.
      • With that, the cover is off.
      Ask FixBot
    10. OVNS Firework Refill Technique, Remove the front cover: step 10, image 1 of 2 OVNS Firework Refill Technique, Remove the front cover: step 10, image 2 of 2
      • Insert an opening pick in one side of the front cover to disengage the two latching tabs on that side.
      • Insert it far enough to be seen through the rectangular cutouts for the tabs.
      Ask FixBot
    11. OVNS Firework Refill Technique: step 11, image 1 of 3 OVNS Firework Refill Technique: step 11, image 2 of 3 OVNS Firework Refill Technique: step 11, image 3 of 3
      • On the other side, insert your pry tool.
      • Lever the tool up to both free the tabs and slide the vape out of the front cover.
      Ask FixBot
    12. OVNS Firework Refill Technique: step 12, image 1 of 1
      • The front cover has been removed.
      Ask FixBot
    13. OVNS Firework Refill Technique, Disconnect the display ribbon cable: step 13, image 1 of 2 OVNS Firework Refill Technique, Disconnect the display ribbon cable: step 13, image 2 of 2
      • Use the point of a spudger to flip up the retaining latch on the display's circuit board.
      Ask FixBot
    14. OVNS Firework Refill Technique: step 14, image 1 of 2 OVNS Firework Refill Technique: step 14, image 2 of 2
      • Unplug the ribbon cable with a pair of tweezers.
      Ask FixBot
    15. OVNS Firework Refill Technique, Remove the housing: step 15, image 1 of 2 OVNS Firework Refill Technique, Remove the housing: step 15, image 2 of 2
      • Start by inserting your pry tool in the bottom seam on one side. Separate the housing slightly.
      • Flip the vape over and pop the other side loose.
      • Do not attempt to pull the vape out of the top housing; the tank is only secured by the battery wires and you may damage them if you try. The next page will show you how to remove it.
      Ask FixBot
    16. OVNS Firework Refill Technique: step 16, image 1 of 3 OVNS Firework Refill Technique: step 16, image 2 of 3 OVNS Firework Refill Technique: step 16, image 3 of 3
      • Holding the vape upright, push the tank out of the cover. Locate the white absorbent pad visible in the air passage.
      • Press down on the pad.
      • Once enough of the tank is exposed, you can grasp that and pull the tank/battery/electronics assembly out.
      Ask FixBot
    17. OVNS Firework Refill Technique: step 17, image 1 of 1
      • The tank cover has been removed.
      Ask FixBot
    1. OVNS Firework Refill Technique, Remove the tank seal: step 18, image 1 of 2 OVNS Firework Refill Technique, Remove the tank seal: step 18, image 2 of 2
      • Here you see the white tank seal in place on top of the tank.
      • Lift off the tank seal and set it aside.
      Ask FixBot
    2. OVNS Firework Refill Technique, Fill with ejuice: step 19, image 1 of 2 OVNS Firework Refill Technique, Fill with ejuice: step 19, image 2 of 2
      • Go around the edges of the foam, filling the space between it and the wall of the tank.
      • Be careful not to get too much liquid down the center tube. A small amount will be caught by the cotton, but more can end up at the bottom of the tank, getting into the electronics.
      • If you accidentally get liquid in the tube, turn it upside down and shake it; enough will come out that it won't cause problems.
      Ask FixBot
    3. OVNS Firework Refill Technique: step 20, image 1 of 2 OVNS Firework Refill Technique: step 20, image 2 of 2
      • Continue around the edges, filling it evenly.
      Ask FixBot
    4. OVNS Firework Refill Technique: step 21, image 1 of 2 OVNS Firework Refill Technique: step 21, image 2 of 2
      • This is what it will look like as you start out, with the liquid saturating the foam. Continue filling evenly around the edges of the opening.
      • Finally, here's one that is sufficiently full for use. It doesn't need to be completely saturated; too much can overflow and cause problems with the electronics.
      Ask FixBot
Your tank is topped up, so before you put it all back together now is the perfect time to reset the e-level liquid indicator as shown in this guide.
OVNS Firework e-Liquid Level Indicator Reset - iFixit Repair Guide
Author
with
Jerry Wheeler
103,304 Reputation
97 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 42
Past 30 Days: 89
All Time: 98
