OLPC XO-1.5 Screen Portion Replacement
  1. OLPC XO-1.5 Screen Portion Replacement, Battery: step 1, image 1 of 1
    • Place the laptop upside down with the handle away from you.
  2. OLPC XO-1.5 Screen Portion Replacement: step 2, image 1 of 1
    • Slide the tabs out, towards the green edges, to show the open lock symbol.
    • The right tab will stay in place, but the left tab must be held in position while you remove the battery.
  3. OLPC XO-1.5 Screen Portion Replacement: step 3, image 1 of 3 OLPC XO-1.5 Screen Portion Replacement: step 3, image 2 of 3 OLPC XO-1.5 Screen Portion Replacement: step 3, image 3 of 3
    • Lift the middle of the battery to remove it.
  4. OLPC XO-1.5 Screen Portion Replacement, Screen Portion: step 4, image 1 of 1
    • Using the Phillips screwdriver, unscrew the 5 size M2 x .4 x 4mm screws underneath the battery.
  5. OLPC XO-1.5 Screen Portion Replacement: step 5, image 1 of 1
    • Turn the laptop so that the red XO symbol is right side up.
    • Pull off the white plastic panel with your fingers. There will be 4 tabs that hold the white panel in place. It will require moderate force to remove.
    • If you are having difficulty pulling off the white plastic panel, use a spudger.
  6. OLPC XO-1.5 Screen Portion Replacement: step 6, image 1 of 1
    • Unscrew the 4 size M2 x .4 x 4mm screws that are connected to the green plastic.
  7. OLPC XO-1.5 Screen Portion Replacement: step 7, image 1 of 1
    • Unplug the white connector with black cables on each end on the left of the hinge.
  8. OLPC XO-1.5 Screen Portion Replacement: step 8, image 1 of 1
    • Using the Phillips screwdriver, unscrew the 4 size M3 x .5 x 5mm screws holding the metal to the rest of the laptop.
  9. OLPC XO-1.5 Screen Portion Replacement: step 9, image 1 of 1
    • Carefully lift the top half that has the screen away from the bottom half.
    • There is still one black cable connecting the two halves. Be sure not to break it.
  10. OLPC XO-1.5 Screen Portion Replacement: step 10, image 1 of 2 OLPC XO-1.5 Screen Portion Replacement: step 10, image 2 of 2
    • Rotate the laptop 180 degrees so that the XO logo is now upside down.
    • Push the white plastic back cover down away from the keyboard and top half. This should separate easily from the rest of the device.
  11. OLPC XO-1.5 Screen Portion Replacement: step 11, image 1 of 1
    • Turn the laptop upside down, exposing the bottom inside of the keyboard.
    • This is similar to how the laptop was positioned when removing the battery, except now the white panel is gone.
  12. OLPC XO-1.5 Screen Portion Replacement: step 12, image 1 of 1
    • Slide the black cable (the one that holds the two halves together) out of its connector.
  13. OLPC XO-1.5 Screen Portion Replacement: step 13, image 1 of 2 OLPC XO-1.5 Screen Portion Replacement: step 13, image 2 of 2
    • Separate the screen portion from the rest of the laptop.
Sam Clark
61 Reputation
1 Guide authored
Cal Poly, Team 3-19, Amido Fall 2012 Member of Cal Poly, Team 3-19, Amido Fall 2012
CPSU-AMIDO-F12S3G19
6 Members
10 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 13
All Time: 1,061
