Nook Tablet Back Cover Replacement
  1. Nook Tablet Back Cover Replacement, Back Cover: step 1, image 1 of 1
    • Flip the Nook over.
  2. Nook Tablet Back Cover Replacement: step 2, image 1 of 2 Nook Tablet Back Cover Replacement: step 2, image 2 of 2
    • Lift the flap that reads "Nook" to reveal the tape that is underneath. Remove the memory card if one is present.
    • Remove the tape covering the round holes to reveal two T5 Torx screws.
    • Remove the two T5 Torx screws securing the back cover.
  3. Nook Tablet Back Cover Replacement: step 3, image 1 of 2 Nook Tablet Back Cover Replacement: step 3, image 2 of 2
    • Insert the flat end of a spudger between the front panel and the rear assembly.
    • Though these photos show a screwdriver, use a spudger or plastic opening tool in order to prevent damage to the device.
    • Use a spudger to lift the the back panel from the rest of the Nook.
  4. Nook Tablet Back Cover Replacement: step 4, image 1 of 2 Nook Tablet Back Cover Replacement: step 4, image 2 of 2
    • Slide the spudger around the edges of the Nook to loosen the back panel.
  5. Nook Tablet Back Cover Replacement: step 5, image 1 of 1
    • Pull the back panel off the Nook.
Jacob Metzinger
89 Reputation
2 Guides authored
Cal Poly, Team 1-4, Propen Fall 2012 Member of Cal Poly, Team 1-4, Propen Fall 2012
CPSU-PROPEN-F12S1G4
4 Members
14 Guides authored
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 17
All Time: 5,869
