Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Introduction
Go to step 1 ↓This step-by-step guide is designed to help you disassemble the Nokia 3100b to access and replace or inspect its microphone. The microphone is a crucial component of the phone, as it captures the sound you produce during calls, ensuring clear communication. Whether you're troubleshooting audio issues or replacing a faulty microphone, this guide will provide clear and concise instructions to navigate the process with ease.
Before beginning, ensure you have a clean, well-lit workspace and are equipped with the necessary tools for disassembly. Make sure to power off your phone, disconnect it from the charger, and remove the battery before you begin this repair.
Tools
Gently pull back the small metal frame holding the SIM card into place, and lift open the frame.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
