Nintendo Wii U Pro Controller D Pad Replacement
  1. Nintendo Wii U Pro Controller D Pad Replacement, Battery: step 1, image 1 of 1
    • Turn the controller over to reveal the battery cover.
    • Use the J000 screwdriver to remove the screw that secures the battery cover.
  2. Nintendo Wii U Pro Controller D Pad Replacement: step 2, image 1 of 2 Nintendo Wii U Pro Controller D Pad Replacement: step 2, image 2 of 2
    • Remove the battery from the controller by inserting the plastic spudger into the small gap on the bottom right of the battery.
    • Use the spudger as a lever to pry up and remove the battery from the compartment.
  3. Nintendo Wii U Pro Controller D Pad Replacement, Joystick: step 3, image 1 of 1
    • Remove the eight 5.5 mm Y0 screws.
  4. Nintendo Wii U Pro Controller D Pad Replacement: step 4, image 1 of 2 Nintendo Wii U Pro Controller D Pad Replacement: step 4, image 2 of 2
    • Now that you have removed all of the screws, carefully separate and remove the bottom half of the controller shell from the top half.
    • If you feel any resistance when pulling the shells apart, use a spudger to separate the left and right trigger contact assemblies from the bottom shell.
  5. Nintendo Wii U Pro Controller D Pad Replacement: step 5, image 1 of 1
    • Move the right trigger and sensor out of the way.
    • Remove the 4 mm JIS #0 screw.
  6. Nintendo Wii U Pro Controller D Pad Replacement: step 6, image 1 of 1
    • Move the left trigger and sensor out of the way.
  7. Nintendo Wii U Pro Controller D Pad Replacement: step 7, image 1 of 1
    • Remove the joysticks and motherboard from the controller’s shell.
  8. Nintendo Wii U Pro Controller D Pad Replacement: step 8, image 1 of 1
    • Carefully pull the rubber thumbsticks off of the electronic bearings to remove the joysticks.
  9. Nintendo Wii U Pro Controller D Pad Replacement, D Pad: step 9, image 1 of 1
    • Locate the two 4 mm motherboard screws, shown circled in red, with the J0 screwdriver.
  10. Nintendo Wii U Pro Controller D Pad Replacement: step 10, image 1 of 1
    • Remove the motherboard and connected components. The rubber pad of the D Pad is indicated in the image by the red arrow.
  11. Nintendo Wii U Pro Controller D Pad Replacement: step 11, image 1 of 1
    • Remove the rubber pad and D Pad button. The D Pad can be replaced by the new D Pad or be cleaned to improve condition.
Jesse Burton
586 Reputation
3 Guides authored
IUPUI, Team 2-2, Harley Fall 2015 Member of IUPUI, Team 2-2, Harley Fall 2015
IUPUI-HARLEY-F15S2G2
4 Members
15 Guides authored
Past 24 Hours: 0
Past 7 Days: 13
Past 30 Days: 43
All Time: 4,457
