Nintendo Switch Micro SD Card Reader Replacement
  1. Nintendo Switch Micro SD Card Reader Replacement, Release the Joy Con controller locking tabs: step 1, image 1 of 3 Nintendo Switch Micro SD Card Reader Replacement, Release the Joy Con controller locking tabs: step 1, image 2 of 3 Nintendo Switch Micro SD Card Reader Replacement, Release the Joy Con controller locking tabs: step 1, image 3 of 3
    • Before you begin this repair, make sure the device is completely powered off.
    • Press and hold down the small round button on the back of the Joy Con controller.
    • While you hold down the button, slide the controller upward.
  2. Nintendo Switch Micro SD Card Reader Replacement, Remove the Joy Con controllers: step 2, image 1 of 3 Nintendo Switch Micro SD Card Reader Replacement, Remove the Joy Con controllers: step 2, image 2 of 3 Nintendo Switch Micro SD Card Reader Replacement, Remove the Joy Con controllers: step 2, image 3 of 3
    • Continue sliding the Joy Con upward until it's completely removed from the console.
    • Repeat this same process for the other Joy Con.
  3. Nintendo Switch Micro SD Card Reader Replacement, Remove the back-side screws: step 3, image 1 of 1
    Tool used on this step:
    Magnetic Project Mat
    $19.95
    Buy
    • Use a Y00 screwdriver to remove the four 6.3 mm-long screws securing the rear panel.
  4. Nintendo Switch Micro SD Card Reader Replacement, Remove the top and bottom screws: step 4, image 1 of 2 Nintendo Switch Micro SD Card Reader Replacement, Remove the top and bottom screws: step 4, image 2 of 2
    • Use a JIS 000 driver or an official iFixit PH 000 driver to remove the following screws securing the rear panel:
    • One 2.5 mm-long screw on the top edge of the device
    • Two 2.5 mm-long screws on the bottom edge of the device
    • To prevent these tight screws from stripping, apply firm downward force, work slowly and try another JIS 000 or PH 000 driver if the screws won't come out.
  5. Nintendo Switch Micro SD Card Reader Replacement: step 5, image 1 of 2 Nintendo Switch Micro SD Card Reader Replacement: step 5, image 2 of 2
    • Use a JIS 000 screwdriver or an official iFixit PH 000 driver to remove the two 3.8 mm center screws on the sides of the device (one on each side).
  6. Nintendo Switch Micro SD Card Reader Replacement: step 6, image 1 of 2 Nintendo Switch Micro SD Card Reader Replacement: step 6, image 2 of 2
    • Use your finger to flip up the kickstand on the back of the device.
    • If there's a microSD card in the microSD card slot, remove it now before you continue to the next step.
  7. Nintendo Switch Micro SD Card Reader Replacement: step 7, image 1 of 1
    • Use a JIS 000 screwdriver or an official iFixit PH 000 driver to remove the 1.6 mm screw in the kickstand well.
    • Close the kickstand.
  8. Nintendo Switch Micro SD Card Reader Replacement: step 8, image 1 of 3 Nintendo Switch Micro SD Card Reader Replacement: step 8, image 2 of 3 Nintendo Switch Micro SD Card Reader Replacement: step 8, image 3 of 3
    • Open the game card cartridge flap.
    • The game card cartridge flap attaches to the other half of the plastic shell, preventing you from completely lifting up the rear panel if it's closed.
    • Lift the rear panel up from the bottom of the device and remove it.
  9. Nintendo Switch Micro SD Card Reader Replacement, Remove the microSD card reader: step 9, image 1 of 1
    • Use a JIS 000 screwdriver to remove the 3.1 mm screw securing the microSD card reader to the device.
  10. Nintendo Switch Micro SD Card Reader Replacement: step 10, image 1 of 2 Nintendo Switch Micro SD Card Reader Replacement: step 10, image 2 of 2
    • Use your fingers or a pair of tweezers to lift the microSD card reader straight up from the device to disconnect and remove it.
    • During reassembly, make sure the press connector underneath the foam pad is firmly connected to the motherboard
Craig Lloyd
35,916 Reputation
82 Guides authored
Past 24 Hours: 153
Past 7 Days: 772
Past 30 Days: 3,507
All Time: 197,467
