Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Tools
Use your finger or the flat end of a spudger to flip up the locking flap on the screen cable ZIF connector.
Flip the console over so the screen is facing up.
Apply a heated iOpener to the bottom edge of the screen for two minutes.
Apply a suction handle to the bottom edge of the screen, above the right speaker and ventilation cutouts.
Pull up on the handle with a strong, steady force to create a gap between the screen and the frame.
Insert the tip of an opening pick into the gap.
Slide your pick across the bottom edge to separate the adhesive.
Leave your pick inserted in the bottom left corner to prevent the adhesive from resealing.
Apply a heated iOpener to the left edge of the screen for two minutes.
Insert a second opening pick next to the first one and slide it up the left edge of the screen.
Repeat the heating and sliding procedure along the remaining screen edges.
