Nintendo Switch 2 Joy-Con Left Back Cover Replacement
    1. Nintendo Switch 2 Joy-Con Left Back Cover Replacement, Remove the right edge screws: step 1, image 1 of 2 Nintendo Switch 2 Joy-Con Left Back Cover Replacement, Remove the right edge screws: step 1, image 2 of 2
      • Use a tri‑point Y00 driver to remove the two 3.1 mm‑long black screws on the right edge of the controller.
      Ask FixBot
    2. Nintendo Switch 2 Joy-Con Left Back Cover Replacement, Insert an opening pick: step 2, image 1 of 2 Nintendo Switch 2 Joy-Con Left Back Cover Replacement, Insert an opening pick: step 2, image 2 of 2
      • Insert an opening pick into the gap underneath the bumper button on the left side of the controller, with a point of the pick pointing downwards.
      • Pry up to slightly lift the plastic strip running across the left edge of the controller.
      Ask FixBot
    3. Nintendo Switch 2 Joy-Con Left Back Cover Replacement, Separate the plastic strip: step 3, image 1 of 3 Nintendo Switch 2 Joy-Con Left Back Cover Replacement, Separate the plastic strip: step 3, image 2 of 3 Nintendo Switch 2 Joy-Con Left Back Cover Replacement, Separate the plastic strip: step 3, image 3 of 3
      • Slide the opening pick around to the front of the controller.
      • Slide the opening pick down the plastic strip to separate the clips and adhesive securing it to the controller's body.
      Ask FixBot
    4. Nintendo Switch 2 Joy-Con Left Back Cover Replacement, Remove the plastic strip: step 4, image 1 of 3 Nintendo Switch 2 Joy-Con Left Back Cover Replacement, Remove the plastic strip: step 4, image 2 of 3 Nintendo Switch 2 Joy-Con Left Back Cover Replacement, Remove the plastic strip: step 4, image 3 of 3
      • Pry up on the bottom edge of the plastic strip with slow, steady force.
      • Repeat this prying action along the length of the strip until it's fully detached.
      Ask FixBot
    5. Nintendo Switch 2 Joy-Con Left Back Cover Replacement: step 5, image 1 of 1
      • Remove the plastic strip.
      Ask FixBot
    6. Nintendo Switch 2 Joy-Con Left Back Cover Replacement, Remove the left edge screws: step 6, image 1 of 2 Nintendo Switch 2 Joy-Con Left Back Cover Replacement, Remove the left edge screws: step 6, image 2 of 2
      • Remove the two screws on the left edge of the controller:
      • One 3.1 mm‑long tri‑point Y00 black screw
      • One 3.0 mm‑long JIS 00 silver screw
      • You can use a Phillips screwdriver in a pinch, but you risk damaging or stripping the screw. Push down firmly on the screwdriver and twist slowly. Often, switching drivers may help, even if they're the same size.
      Ask FixBot
    7. Nintendo Switch 2 Joy-Con Left Back Cover Replacement, Insert an opening pick: step 7, image 1 of 3 Nintendo Switch 2 Joy-Con Left Back Cover Replacement, Insert an opening pick: step 7, image 2 of 3 Nintendo Switch 2 Joy-Con Left Back Cover Replacement, Insert an opening pick: step 7, image 3 of 3
      • Don't try to remove the back cover yet.
      • Insert an opening pick into the gap between the front and back halves of the controller on its left side.
      • Slide the pick down the controller to disengage the clips.
      • Leave the opening pick at the bottom of the controller's left edge, just before its curve.
      • The opening pick will fall out once the back cover is removed. If it falls out before then, put it back to keep the two halves separated.
      Ask FixBot
    8. Nintendo Switch 2 Joy-Con Left Back Cover Replacement, Insert a second opening pick: step 8, image 1 of 3 Nintendo Switch 2 Joy-Con Left Back Cover Replacement, Insert a second opening pick: step 8, image 2 of 3 Nintendo Switch 2 Joy-Con Left Back Cover Replacement, Insert a second opening pick: step 8, image 3 of 3
      • Hold the controller upside-down.
      • Insert a point of another opening pick next to the release button at the top of the controller.
      • Use the opening pick to press the release button through the gap.
      Ask FixBot
    9. Nintendo Switch 2 Joy-Con Left Back Cover Replacement, Release the back cover: step 9, image 1 of 3 Nintendo Switch 2 Joy-Con Left Back Cover Replacement, Release the back cover: step 9, image 2 of 3 Nintendo Switch 2 Joy-Con Left Back Cover Replacement, Release the back cover: step 9, image 3 of 3
      • The back cover is connected to the controller by a cable at the bottom. Don't try to remove it completely yet.
      • While holding the release button with the opening pick, use your other hand to slide the back cover down to release the clips securing it to the controller's body.
      • Open the back cover.
      Ask FixBot
    10. Nintendo Switch 2 Joy-Con Left Back Cover Replacement, Remove the back cover: step 10, image 1 of 2 Nintendo Switch 2 Joy-Con Left Back Cover Replacement, Remove the back cover: step 10, image 2 of 2
      • Firmly grasp the two wires (blue and white) above the rumble motor connector, located at the bottom of the controller's board, and pull the beige connector out of its socket.
      • Pulling the cable won't damage it, but don't dig your nails into the plastic sheathing.
      • Remove the back cover.
      Ask FixBot
redratchet21
2,994 Reputation
12 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 38
Past 30 Days: 131
All Time: 598
