Nintendo Switch 2 Joy-Con Action Buttons (ABXY) Replacement
    1. Nintendo Switch 2 Joy-Con Action Buttons (ABXY) Replacement, Remove the left edge screws: step 1, image 1 of 2 Nintendo Switch 2 Joy-Con Action Buttons (ABXY) Replacement, Remove the left edge screws: step 1, image 2 of 2
      • Use a tri-point Y00 driver to remove the two 3.1 mm‑long black screws on the left edge of the controller.
      Ask FixBot
    2. Nintendo Switch 2 Joy-Con Action Buttons (ABXY) Replacement, Insert an opening pick: step 2, image 1 of 3 Nintendo Switch 2 Joy-Con Action Buttons (ABXY) Replacement, Insert an opening pick: step 2, image 2 of 3 Nintendo Switch 2 Joy-Con Action Buttons (ABXY) Replacement, Insert an opening pick: step 2, image 3 of 3
      • Insert an opening pick into the gap underneath the bumper button on the right side of the controller, with a point of the pick pointing downwards.
      • Pry up to slightly lift the plastic strip running across the right edge of the controller.
      • Slide the opening pick around to the front of the controller.
      Ask FixBot
    3. Nintendo Switch 2 Joy-Con Action Buttons (ABXY) Replacement, Separate the plastic strip: step 3, image 1 of 3 Nintendo Switch 2 Joy-Con Action Buttons (ABXY) Replacement, Separate the plastic strip: step 3, image 2 of 3 Nintendo Switch 2 Joy-Con Action Buttons (ABXY) Replacement, Separate the plastic strip: step 3, image 3 of 3
      • Slide the opening pick down the plastic strip to separate the clips and adhesive securing it to the controller's body.
      Ask FixBot
    4. Nintendo Switch 2 Joy-Con Action Buttons (ABXY) Replacement, Remove the plastic strip: step 4, image 1 of 3 Nintendo Switch 2 Joy-Con Action Buttons (ABXY) Replacement, Remove the plastic strip: step 4, image 2 of 3 Nintendo Switch 2 Joy-Con Action Buttons (ABXY) Replacement, Remove the plastic strip: step 4, image 3 of 3
      • Pry up on the bottom edge of the plastic strip with slow, steady force.
      • Repeat this prying action along the length of the strip until it's fully detached.
      Ask FixBot
    5. Nintendo Switch 2 Joy-Con Action Buttons (ABXY) Replacement: step 5, image 1 of 1
      • Remove the plastic strip.
      Ask FixBot
    6. Nintendo Switch 2 Joy-Con Action Buttons (ABXY) Replacement, Remove the right edge screws: step 6, image 1 of 2 Nintendo Switch 2 Joy-Con Action Buttons (ABXY) Replacement, Remove the right edge screws: step 6, image 2 of 2
      • Remove the two screws on the right edge of the controller:
      • One 3.1 mm‑long tri-point Y00 black screw
      • One 3.0 mm‑long JIS 00 silver screw
      • You can use a Phillips screwdriver in a pinch, but you risk damaging or stripping the screw. Push down firmly on the screwdriver and twist slowly. Often, switching drivers may help, even if they're the same size.
      Ask FixBot
    7. Nintendo Switch 2 Joy-Con Action Buttons (ABXY) Replacement, Insert an opening pick: step 7, image 1 of 2 Nintendo Switch 2 Joy-Con Action Buttons (ABXY) Replacement, Insert an opening pick: step 7, image 2 of 2
      • Don't try to remove the back cover yet.
      • Insert an opening pick into the gap between the front and back halves of the controller on its right side.
      • Slide the pick down the controller to disengage the clips.
      • Leave the opening pick at the bottom of the controller's right edge, just before its curve.
      • The opening pick will fall out once the back cover is removed. If it falls out before then, put it back to keep the two halves separated.
      Ask FixBot
    8. Nintendo Switch 2 Joy-Con Action Buttons (ABXY) Replacement, Insert a second opening pick: step 8, image 1 of 3 Nintendo Switch 2 Joy-Con Action Buttons (ABXY) Replacement, Insert a second opening pick: step 8, image 2 of 3 Nintendo Switch 2 Joy-Con Action Buttons (ABXY) Replacement, Insert a second opening pick: step 8, image 3 of 3
      • Hold the controller upside-down.
      • Insert a point of another opening pick next to the release button towards the top of the controller.
      • Use the opening pick to press the release button through the gap.
      Ask FixBot
    9. Nintendo Switch 2 Joy-Con Action Buttons (ABXY) Replacement, Release the back cover: step 9, image 1 of 3 Nintendo Switch 2 Joy-Con Action Buttons (ABXY) Replacement, Release the back cover: step 9, image 2 of 3 Nintendo Switch 2 Joy-Con Action Buttons (ABXY) Replacement, Release the back cover: step 9, image 3 of 3
      • The back cover is connected to the controller by a cable at the bottom. Don't try to remove it completely yet.
      • While holding the release button with the opening pick, use your other hand to slide the back cover down to release the clips securing it to the controller's body.
      • Open the back cover.
      Ask FixBot
    10. Nintendo Switch 2 Joy-Con Action Buttons (ABXY) Replacement, Remove the back cover: step 10, image 1 of 3 Nintendo Switch 2 Joy-Con Action Buttons (ABXY) Replacement, Remove the back cover: step 10, image 2 of 3 Nintendo Switch 2 Joy-Con Action Buttons (ABXY) Replacement, Remove the back cover: step 10, image 3 of 3
      • Firmly grasp the two wires (yellow and white) above the rumble motor connector, located at the bottom of the controller's board, and pull the beige connector out of its socket.
      • Pulling the cable won't damage it, but don't dig your nails into the plastic sheathing.
      • Remove the back cover.
      Ask FixBot
    1. Nintendo Switch 2 Joy-Con Action Buttons (ABXY) Replacement, Disconnect the battery: step 11, image 1 of 2 Nintendo Switch 2 Joy-Con Action Buttons (ABXY) Replacement, Disconnect the battery: step 11, image 2 of 2
      • Use tweezers or your fingers to firmly grip the battery cable's white JST connector and pull straight away from its socket to disconnect it.
      • Once partially lifted, reposition your fingers/tweezers to beneath the connector's upper lip to increase your grip.
      Ask FixBot
    2. Nintendo Switch 2 Joy-Con Action Buttons (ABXY) Replacement, Remove the battery: step 12, image 1 of 2 Nintendo Switch 2 Joy-Con Action Buttons (ABXY) Replacement, Remove the battery: step 12, image 2 of 2
      • Insert a flat edge of an opening pick into the gap between the battery and the battery well.
      Ask FixBot
    3. Nintendo Switch 2 Joy-Con Action Buttons (ABXY) Replacement: step 13, image 1 of 3 Nintendo Switch 2 Joy-Con Action Buttons (ABXY) Replacement: step 13, image 2 of 3 Nintendo Switch 2 Joy-Con Action Buttons (ABXY) Replacement: step 13, image 3 of 3
      Tool used on this step:
      iFixit Adhesive Remover
      $19.99
      Buy
      • Pry the battery up slowly with steady force to release the adhesive.
      • Don't bend or crease the battery—apply steady force and give the adhesive time to release.
      • If it feels stubborn, apply a few drops of adhesive remover or high-concentration (90% or higher) isopropyl alcohol to the battery side of the pick while it's inserted and allow it to run under the battery. Be careful not to spill it elsewhere in the controller.
      • If you're using adhesive remover, follow these preparation steps first.
      • Remove the battery.
      Ask FixBot
    1. Nintendo Switch 2 Joy-Con Action Buttons (ABXY) Replacement, Disconnect the board: step 14, image 1 of 3 Nintendo Switch 2 Joy-Con Action Buttons (ABXY) Replacement, Disconnect the board: step 14, image 2 of 3 Nintendo Switch 2 Joy-Con Action Buttons (ABXY) Replacement, Disconnect the board: step 14, image 3 of 3
      • Repeat this procedure to disconnect the remaining three ZIF connectors on the controller's board.
      Ask FixBot
    2. Nintendo Switch 2 Joy-Con Action Buttons (ABXY) Replacement, Remove the board screws: step 15, image 1 of 2 Nintendo Switch 2 Joy-Con Action Buttons (ABXY) Replacement, Remove the board screws: step 15, image 2 of 2
      • Use a JIS 00 driver to remove the five 3.1 mm‑long black screws securing the board to the controller.
      Ask FixBot
    3. Nintendo Switch 2 Joy-Con Action Buttons (ABXY) Replacement, Lift the board: step 16, image 1 of 2 Nintendo Switch 2 Joy-Con Action Buttons (ABXY) Replacement, Lift the board: step 16, image 2 of 2
      • Insert the point of a spudger between the board and the controller, near the battery connector socket.
      • Pry up on the board enough to grasp its edge with your fingertips.
      Ask FixBot
    4. Nintendo Switch 2 Joy-Con Action Buttons (ABXY) Replacement, Remove the board: step 17, image 1 of 3 Nintendo Switch 2 Joy-Con Action Buttons (ABXY) Replacement, Remove the board: step 17, image 2 of 3 Nintendo Switch 2 Joy-Con Action Buttons (ABXY) Replacement, Remove the board: step 17, image 3 of 3
      • Lift the board by its outer edges to a roughly 45-degree angle, so it's no longer being blocked by the joystick assembly.
      • Make sure the black tape is fully lifted off the back of the joystick module. Work slowly to avoid tearing the tape.
      • Remove the board.
      Ask FixBot
You have made it to the buttons! Use tweezers to remove the membrane, then you can push the button(s) off!
To reassemble your device, follow these instructions in reverse order. Please take your e-waste to a certified recycler.
Button order (counter-clockwise): X-Y-B-A
redratchet21
2,878 Reputation
11 Guides authored
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 51
Past 30 Days: 259
All Time: 968
