Nintendo DS Lite Shoulder Buttons Technique
  1. Nintendo DS Lite Shoulder Buttons Technique, Remove the battery cover: step 1, image 1 of 1
    • Use a Phillips #00 screwdriver to remove the screw securing the battery cover.
  2. Nintendo DS Lite Shoulder Buttons Technique, Remove the lower case: step 2, image 1 of 1
    • Use a spudger to pry out the battery.
    • Pry off the rubber feet.
    • Remove the seven screws securing the lower case:
    • Three tri-wing screws
    • One Phillips screw
    • Two gold Phillips screws
    • One black tri-wing screw
  3. Nintendo DS Lite Shoulder Buttons Technique: step 3, image 1 of 1
    • Carefully pry the bottom cover off.
    • Remove the shoulder buttons by pulling out the metal pegs that secure them to DS.
    • The triggers are held in by tiny metal pegs and springs. Keep track of each piece.
  4. Nintendo DS Lite Shoulder Buttons Technique: step 4, image 1 of 3 Nintendo DS Lite Shoulder Buttons Technique: step 4, image 2 of 3 Nintendo DS Lite Shoulder Buttons Technique: step 4, image 3 of 3
    • You can now access the micro-button component and replace or repair anything as needed.
Past 24 Hours: 6
Past 7 Days: 47
Past 30 Days: 230
All Time: 6,674
