HTC Touch Camera Lens Replacement
Views: 3.2K
View statistics:
Past 24 Hours:
2
Past 7 Days:
18
Past 30 Days:
86
All Time:
3,242
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 5
5 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 - 45 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
If your photos appear blurry or the camera lens is visibly cracked or scratched, replacing the camera lens on your HTC Touch can restore photo clarity. This guide will show you how to safely remove and replace the rear camera lens using basic tools.
Warning: Make sure you are grounded whenever handling a circuit or logic board.
Before you begin this repair, make sure to power off your phone and disconnect the charger.
Tools
    1. HTC Touch Camera Lens Replacement, Camera Lens: step 1, image 1 of 1
      • Slide the back panel upward using the grip at the bottom until it releases.
      • Lift and remove the panel.
      Ask FixBot
    2. HTC Touch Camera Lens Replacement: step 2, image 1 of 1
      • Use your fingers to grip the battery and remove it from its compartment.
      • Set it aside in a safe place.
      Ask FixBot
    3. HTC Touch Camera Lens Replacement: step 3, image 1 of 1
      • Remove the 4 torx-head screws in the corners of the phone using the T5 Torx Screwdriver.
      • Keep the screws in a safe place so you don’t lose them.
      Ask FixBot
    4. HTC Touch Camera Lens Replacement: step 4, image 1 of 2 HTC Touch Camera Lens Replacement: step 4, image 2 of 2
      • Use the plastic opening tool to remove the front panel from the phone.
      • Place a spudger or an opening tool under the edge of the press connector and pry straight up to disconnect it.
      • Make sure to pry under the edge of the connector itself, and not under the socket on the board. Otherwise, you risk permanently damaging the socket.
      • To reconnect, align the connector carefully over its socket and press down with your fingertip—first on one of the short sides, then the other—until it clicks into place. Don't try to force the connector into place. If you're having trouble, reposition it and try again.
      Ask FixBot
    5. HTC Touch Camera Lens Replacement: step 5, image 1 of 1
      • Unscrew the torx-head screws at the base of the LCD screen using the T5 Torx Screwdriver.
      Ask FixBot
    6. HTC Touch Camera Lens Replacement: step 6, image 1 of 2 HTC Touch Camera Lens Replacement: step 6, image 2 of 2
      • Seperate the motherboard from the black plastic casing.
      • Unplug the black and red wire from the motherboard.
      • Unplug the black and red wire from the black plastic casing.
      Ask FixBot
    7. HTC Touch Camera Lens Replacement: step 7, image 1 of 1
      • Use a spudger to lift the black flap lock next to the orange ribbon cable and slide the cable from the socket.
      • Remove the LCD screen.
      Ask FixBot
    8. HTC Touch Camera Lens Replacement: step 8, image 1 of 1
      • Remove the camera lens from the motherboard using the plastic opening tool.
      • Align and insert the new camera lens into the opening. Press it into place until it is secure.
      Ask FixBot
You've successfully replaced your HTC Touch's camera lens! Test your camera to ensure the new lens works properly and your images are clear. To reassemble your device, follow these instructions in reverse order.
2 other people completed this guide.
Sehyun
69 Reputation
1 Guide authored
Cal Poly, Team 15-12, Regan Spring 2011 Member of Cal Poly, Team 15-12, Regan Spring 2011
CPSU-REGAN-S11S15G12
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 86
All Time: 3,242
