Nintendo 3DS Upper Display Assembly Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Nintendo 3DS Upper Display Assembly Replacement, Upper Display Assembly: step 1, image 1 of 1
    • Remove the 3D adjustment switch from the front display bezel.
    • This step is not necessary for disassembly, but the switch is likely to fall out on its own. By removing it yourself, you reduce the chance of losing it.
  2. Nintendo 3DS Upper Display Assembly Replacement: step 2, image 1 of 3 Nintendo 3DS Upper Display Assembly Replacement: step 2, image 2 of 3 Nintendo 3DS Upper Display Assembly Replacement: step 2, image 3 of 3
    • Insert a metal probe into the space above the ABXY buttons with the point touching the metal hinge.
    • Push the hinge towards the center of the upper case. This will require a fair amount of force.
    • Before and after images of the hinge location when looking at the back of the upper display are shown.
  3. Nintendo 3DS Upper Display Assembly Replacement: step 3, image 1 of 3 Nintendo 3DS Upper Display Assembly Replacement: step 3, image 2 of 3 Nintendo 3DS Upper Display Assembly Replacement: step 3, image 3 of 3
    • Slowly pull the upper display assembly away from the upper case.
    • Make sure that the various ribbon cables are being fed through the slit in the upper case.
    • Separate the upper display assembly from the upper case.
David Hodson
150,791 Reputation
127 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 229
