15% Off Selected iFixit Tools — Limited Time
Nintendo 3DS Right Shoulder Button Replacement
  1. Nintendo 3DS Right Shoulder Button Replacement, Loosen the rear screws: step 1, image 1 of 1
    Tool used on this step:
    Phillips #00 Screwdriver
    $5.49
    Buy
    • Use a Phillips PH00 screwdriver to loosen the four screws along the top of the back cover.
    • All screws in this device are JIS screws. Official iFixit PH000-PH1 Phillips screwdrivers are designed to be compatible with JIS screws, so they are safe to use. Using a screwdriver other than an official iFixit screwdriver or a JIS screwdriver may result in stripped screws.
    • The screws are held in place by locking washers, and will not come out of the back cover.
    Ask FixBot
  2. Nintendo 3DS Right Shoulder Button Replacement, Remove the rear cover: step 2, image 1 of 2 Nintendo 3DS Right Shoulder Button Replacement, Remove the rear cover: step 2, image 2 of 2
    • Hold the device in one hand and turn it over.
    • Grab the top edge of the back cover with your opposite hand so that the cover does not fall back into place.
    • Flip the 3DS over again so that the back cover is facing up.
    • Pull the back cover up and away from the rest of the device to remove it.
    Ask FixBot
  3. Nintendo 3DS Right Shoulder Button Replacement, Battery: step 3, image 1 of 3 Nintendo 3DS Right Shoulder Button Replacement, Battery: step 3, image 2 of 3 Nintendo 3DS Right Shoulder Button Replacement, Battery: step 3, image 3 of 3
    • Insert a plastic opening tool into the notch in the lower case above the battery.
    • Pry the battery up with the plastic opening tool.
    • Grab the top edge of the battery and lift it out of the lower case.
    Ask FixBot
  4. Nintendo 3DS Right Shoulder Button Replacement, Lower Case: step 4, image 1 of 1
    • Use a JIS #00 screwdriver to remove the nine 6.3 mm black screws from the lower case.
    • JIS (Japanese Industrial Standards) screws are not the same as Phillips. To avoid stripping these screws, make sure you are using a JIS #00 screwdriver and not a PHILLIPS #00 screwdriver. You can use a PHILLIPS #00 with a lot of downwards force but be warned this will deform the screw head and you risk stripping it.
    • iFixit's Phillips head screwdriver is designed to reduce damage on JIS head screws so it should be fine to use, still apply more force. Make sure it's iFixit's official Phillips screwdriver as we are unaware of any other manufacturer who does this.
    • Use a JIS #00 screwdriver to remove the 2.4 mm silver screw above the game cartridge slot.
    Ask FixBot
  5. Nintendo 3DS Right Shoulder Button Replacement: step 5, image 1 of 3 Nintendo 3DS Right Shoulder Button Replacement: step 5, image 2 of 3 Nintendo 3DS Right Shoulder Button Replacement: step 5, image 3 of 3
    • Lift the bottom edge of the lower case off the rest of the 3DS.
    • There are still two ribbon cables connecting the mother board to the case, so be sure not to pull the lower case all the way off.
    • Use a plastic opening tool to pry the shoulder button ribbon cables off their sockets on the motherboard.
    • Remove the lower case from the device.
    Ask FixBot
  6. Nintendo 3DS Right Shoulder Button Replacement, Right Shoulder Button: step 6, image 1 of 3 Nintendo 3DS Right Shoulder Button Replacement, Right Shoulder Button: step 6, image 2 of 3 Nintendo 3DS Right Shoulder Button Replacement, Right Shoulder Button: step 6, image 3 of 3
    • Remove the three 3.6 mm Phillips screws securing the metal battery shield to the lower case.
    • Lift the battery shield up and out of the lower case.
    Ask FixBot
  7. Nintendo 3DS Right Shoulder Button Replacement: step 7, image 1 of 1
    • Remove the 3.6 mm Phillips screw from the right shoulder button cover.
    Ask FixBot
  8. Nintendo 3DS Right Shoulder Button Replacement: step 8, image 1 of 3 Nintendo 3DS Right Shoulder Button Replacement: step 8, image 2 of 3 Nintendo 3DS Right Shoulder Button Replacement: step 8, image 3 of 3
    • Insert a plastic opening tool under the left side of the right shoulder button cover.
    • Pry the black plastic cover up from the lower case.
    • Grab the cover and lift it off of the lower case.
    • If the shoulder button contact and ribbon cable come off with the cover, be sure to reinstall them in the correct orientation.
    Ask FixBot
  9. Nintendo 3DS Right Shoulder Button Replacement: step 9, image 1 of 3 Nintendo 3DS Right Shoulder Button Replacement: step 9, image 2 of 3 Nintendo 3DS Right Shoulder Button Replacement: step 9, image 3 of 3
    • Lift the right shoulder button out of the lower case.
    • The shoulder button is held in place by a metal pin, and houses a small spring. Take care not to lose track of either of these pieces when removing the shoulder button.
    Ask FixBot
82 other people completed this guide.
David Hodson
156,229 Reputation
127 Guides authored
20 Guide Comments
Well done, thanks for the help, I had small problems with step 9 because of all those small parts but I managed to put everything back as it was. Thanks again :D
BlackZX - Reply Share
The ribbon came off the socket, now it is stuck and we cannot pull it out. How do you remove the socket without the ribbon. We attempted tweezers, but it did not budge. May have scratched things up a bit too. Help!! Thank you! We just want to pull it out and get another replacement right shoulder ribbon.
misdiva001 - Reply Share
Did you ever figure out how to get it out? I have the same problem. I changed the ribbon with a 3rd party part and the bad solder job broke and the part is still left in the socket. My only option is to use crazy glue and a pin or something small to glue to it and then pull it out…but I don’t have any krazy glue!
Chris - Reply Share
Amazing guide, thank you!!
Daniel O - Reply Share
It was great! Phenomenal! I loved it! But... What happens if I accidentally snapped the L button's ribbon cable..? Can I just replace it..? Somehow..?
dalton haglund - Reply Share
Past 24 Hours: 37
Past 7 Days: 288
Past 30 Days: 1,131
All Time: 138,523
