Replacing Nikon N2000 (F301) Communication Board
  1. Replacing Nikon N2000 (F301) Communication Board, Lens Mount: step 1, image 1 of 1
    • Use a 00 Phillips head screwdriver to remove the four screws from the lens mount.
  2. Replacing Nikon N2000 (F301) Communication Board: step 2, image 1 of 1
    • Remove lens mount from the camera.
    • Be careful not to lose any of the three loose pieces that are under the lens mount.
  3. Replacing Nikon N2000 (F301) Communication Board, Communication Board: step 3, image 1 of 1
    • Remove the three loose parts (spring, small rod, and metal ring) that were under the lens mount and put them aside.
    • Make sure you remember the orientation of the metal ring so that it is easier to put back in the device later.
  4. Replacing Nikon N2000 (F301) Communication Board: step 4, image 1 of 1
    • Use 00 Phillips head screwdriver to remove the screw from the bottom of the front black case.
  5. Replacing Nikon N2000 (F301) Communication Board: step 5, image 1 of 3 Replacing Nikon N2000 (F301) Communication Board: step 5, image 2 of 3 Replacing Nikon N2000 (F301) Communication Board: step 5, image 3 of 3
    • Use 00 Phillips head screwdriver to remove the screws from the top case (6 in all).
  6. Replacing Nikon N2000 (F301) Communication Board: step 6, image 1 of 1
    • Remove the front case from the camera.
    • There is a black plastic ring in the case. Be sure not to remove it, as it can be difficult to put back.
  7. Replacing Nikon N2000 (F301) Communication Board: step 7, image 1 of 1
    • Use a 00 Phillips head screwdriver to remove the screws from either side of the communication board.
  8. Replacing Nikon N2000 (F301) Communication Board: step 8, image 1 of 1
    • Desolder the wires and remove them from the communication board.
    • Note: If you are unfamiliar with soldering techniques, click here for a guide.
Zachary Phillips
247 Reputation
5 Guides authored
Cal Poly, Team 25-26, Garner Spring 2011 Member of Cal Poly, Team 25-26, Garner Spring 2011
CPSU-GARNER-S11S25G26
3 Members
12 Guides authored
Past 24 Hours: 6
Past 7 Days: 16
Past 30 Days: 78
All Time: 6,141
