Introduction
Replacing the inner dome daughterboard is a fairly simple job.
Disconnect the taoglas Wi-Fi Dual Band Antenna by prying with a spudger.
Once the antenna is disconnected, simply pull it off the outside of the inner dome.
Use a T6 Torx screwdriver to undo the three 0.8 mm screws holding the inner dome daughterboard in place.
