Nexus 5X Rear Panel Replacement
  1. Nexus 5X Rear Panel Replacement, SIM Card Tray: step 1, image 1 of 3 Nexus 5X Rear Panel Replacement, SIM Card Tray: step 1, image 2 of 3 Nexus 5X Rear Panel Replacement, SIM Card Tray: step 1, image 3 of 3
    • Insert a SIM card ejection tool into the hole on the SIM card tray, located on the left edge of the phone.
    • Press in to eject the SIM card tray.
    • Remove the SIM card tray.
  2. Nexus 5X Rear Panel Replacement, Rear Panel: step 2, image 1 of 3 Nexus 5X Rear Panel Replacement, Rear Panel: step 2, image 2 of 3 Nexus 5X Rear Panel Replacement, Rear Panel: step 2, image 3 of 3
    • Place an opening pick in the opening of the SIM card tray slot and twist it sideways to release the first plastic clip that holds the rear panel in its place.
    • Slide the opening pick around the top edge of the phone to release the plastic clips that secure the rear panel.
    A guitar pick is a good substitution for the plastic opening tool.
    Sam Sippe - Reply
    Here’s a photo of the location of the 18 tabs that hold the back cover in place
    Steve - Reply
    Twisting sideways didn’t do it for me, but sliding along the edge did. However, at first I didn’t realize that the pick was between the motherboard and midframe, rather than between midframe and back cover like it was supposed to. This led to breaking off a spring-loaded connector on the motherboard, connecting to an antenna (I guess) in the back cover. So far I haven’t noticed any reception issues, but I can’t say for sure.
    In essence: be careful to get the pick towards the back cover, and not “straight in” under the midframe.
    Hampus - Reply
  3. Nexus 5X Rear Panel Replacement: step 3, image 1 of 3 Nexus 5X Rear Panel Replacement: step 3, image 2 of 3 Nexus 5X Rear Panel Replacement: step 3, image 3 of 3
    • Continue to slide the opening pick around all sides of the phone to release all clips that secure the rear panel.
  4. Nexus 5X Rear Panel Replacement: step 4, image 1 of 2 Nexus 5X Rear Panel Replacement: step 4, image 2 of 2
    • Tilt the opening pick to lift the rear panel a little bit.
    • There are two more plastic clips next to the fingerprint sensor. Release them by gently pulling the rear panel.
    • Remove the rear panel.
Repair didn’t go as planned? Check out our Nexus 5X Answers community for troubleshooting help.
26 other people completed this guide.
Dominik Schnabelrauch
204,077 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
135 Members
17,199 Guides authored
One Comment
Bonjour,
Est-ce que vous arriveriez à m'indiquer l'espace disponible (en mm) entre le cache et la batterie svp?
Merci!
Lucas Marti - Reply
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 18
All Time: 8,723
